Wifi Issues
fatman
Wifi Issues
Post by fatman »
Today I had alternate blinking green and blue lights on my wifi module. I unplugged it from the controller, gave it a few minutes and then plugged it back in again. Still the same.
I tried to do a factory reset (both through software and a hard reset with the jumper) and no luck. I finally got teraterm to see the module and did a complete setup, still no luck. I set the IP to static and got some flashing but it's still flashing red and green.
Roberto, I'll send you a PM with a "get e" dump if you have time to look at it.
Anyone have a possible solution?
Fat
