problem whit wifi
Re: problem whit wifi
It's the same procedure explained in the manual.
http://www.reefangel.com/files/Reef%20A ... 20v1.3.pdf
Upload the code, attach the wifi and open tera term.
petruzzelli
Post by petruzzelli »
rimai wrote:It's the same procedure explained in the manual.
ok
but now i have problem whit sketch too big
The code above does not exceed memory.
Don't add it to your own code.
Just use it as is.
You may need to convert to standard libraries if you are getting compile errors: http://forum.reefangel.com/viewtopic.php?f=8&t=2
petruzzelli
rimai wrote:The code above does not exceed memory.
Just use it as is.
1) i know i dont att it
2) i made http://forum.reefangel.com/viewtopic.php?f=8&t=2
but
Binary sketch size: 34512 bytes (of a 30720 byte maximum)
it is my pde
// Autogenerated file by RAGen (v1.0.4.92), (07/27/2011 00:09)
// RA_072711_0009.pde
#define DisplayImages
#define DosingPumpIntervalSetup
#define OverheatSetup
#define DateTimeSetup
#define VersionMenu
#define DirectTempSensor
#define DisplayLEDPWM
#define wifi
#define StandardLightSetup
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
ReefAngel.Relay.On(Port1);
ReefAngel.Relay.On(Port2);
ReefAngel.Relay.On(Port8);
// Specific functions
ReefAngel.StandardLights(Port3);
ReefAngel.DosingPumpRepeat1(Port4);
ReefAngel.DosingPumpRepeat2(Port5);
ReefAngel.StandardFan(Port6);
Ok, so maybe you didn't have ReefAngel_Features.h file setup correctly.
Here is what you need to do:
1. Make sure you close Arduino IDE.
2. Open the file ReefAngel_Features.h located at "Documents\Arduino\libraries\ReefAngel_Features"
3. Change the contents to this:
#define VersionMenu
#define wifi
4. Save the file
5. Open Arduino IDE
6. Upload your PDE file again.
petruzzelli
rimai wrote:Ok, so maybe you didn't have ReefAngel_Features.h file setup correctly.
#define VersionMenu
#define wifi
4. Save the file
5. Open Arduino IDE
sorry change in whit mode' i delete and?
Can you please rephrase? I did not understand. :(
petruzzelli
rimai wrote:Can you please rephrase? I did not understand. :(
sorry
what i do? i opene the features.h and?
Just change the contents.
Delete everything and place just these 2 lines:
#define VersionMenu
#define wifi
petruzzelli
rimai wrote:Just change the contents.
#define VersionMenu
#define wifi
ok roberto
sorry
i have 2 street
the first
settig reefangel whit this software
1) ReefAngelInstaller.exe
2)RAGen-v104-v08516 Installer.exe
second street
1) download arduino 0.22 software on www.arduino.cc
2) download libraries Version 0.8.3.11
3) download curtbinder-ReefAngel-v0.8.5.16-0-ge9a7435
4) RAGen-v104-v08516 Installer.exe
whit ragen i made memory pde and ra pde
if i use this file whit the first street i have sketch too big, if i use the second street it is ok but i dond have comunication whit wifi
why?
Use 1st option.
After you install ReefAngelInstaller and RAGen, you have to one of these 2:
1. Edit the file ReefAngel_Features.h with just the following:
The file has to be edited after you generate your PDE. Everytime you generate a PDE file, RAGen will overwrite whatever change you've made to the file.
#define VersionMenu
#define wifi
2. just uncheck everything from the RAGen when generating the file, except wifi.
You are picking too many choices of RAGen.
petruzzelli
ok tnx
now is all ok
