RA Wifi - 3dBi External Antenna
Re: RA Wifi - 3dBi External Antenna
Looks like your forgetting the magic word...
Save
Save
lnevo wrote:Looks like your forgetting the magic word...
Save
Oops, thank goodness for the edit button!
I use graphical wifi from reef angels website but do not know where in the program I'm writing code. Someone who can explain?
You must enter command mode. To do so, please read the manual.
You will need a serial terminal application such as tera term or putty.
I have downloaded that program and it dosent work. Does it work in graphical wifi? It only shows up some wierd symbols in the window in tera term.
It worked. Thanks Roberto
Just did this mod. Make sure to drill the hole for the connector high enough (closer to the open top) for the wire to clear the circuit board. I also re-located the WiFi adapter away from my Bluetooth adapter as it seemed to be causing some connection issues. I'm considering running the long cable that came with the antenna to the other side of the stand to help mitigate it even more.
Any idea why the screen goes in a loop mode when I connect the wifi module?
