Well, it seems the module is responding correctly as far as the controller is concerned, but the ecotech equipment is not seeing the module for some reason.
You removed the ecotech RF module when you were updating it, correct?
Can you make sure the RF module is plugged back in correctly?
New RF issue
Re: New RF issue
Yes I removed the ecotech module while updating, and I've ensured it was connected correctly after trying to update the module again.
Re: New RF issue
Well, I think you will need to send it back for inspection then.
PM me to get an RMA number.
