I have it set up using the push button and it is showing temp and PH on my iphone but I have no clue where to get the ip address it's using so I can control everything else. I'm sure it's just me but this sure is confusing.
Thanks in advance
WiFi Setup? Please help
Re: WiFi Setup? Please help
That's the problem of using the push-button
It doesn't show the ip address. It makes it much easier to connect with just a couple push buttons, but then you will have to log into your router to find out your ip address.
I wonder if there is a way to somehow scan the network....
Let me try to find an app for that.
So I need the ip address for my computer?
I am guessing this is it but when I put in the ip it still doesn't work
192.168.1.162 Roving Networks
OK got everything to work on the iphone but the portal is still saying
My reefangelid: treetopflyn
Connection Status: Unreachable Address
You need to forward port 2000 in your router to the address that your wifi module gets...
I also use a free dynamic dns service since your ip address from your internet provider is always changing..
d
d
English please
Ok, cool.
Yeah, you must port forward to make it work.
Some info on port forwarding: http://en.wikipedia.org/wiki/Port_forwarding
Some people had very success using this: http://www.simpleportforwarding.com/
Got it thanks everyone
