Listening Reef
- jsclownfish
Listening Reef
More fun with Arduino
Awhile ago I posted my first DIY project that plays sounds and can be triggered from the RA unit http://forum.reefangel.com/viewtopic.php?f=4&t=584. It is fun and cool to show off when guests/kids are over, but I got to thinking it would be really cool if it could listen as well. So I just tested the EasyVR voice recognition module with the RA and with some help from the folks here with the relay masks it actually works. I'm just figuring out how I want to use it, but it is certainly fun to tell the aquarium what you want to happen. For now it can just turn off/on relays, but I'd like to sync it up with the speech tool to communicate status . Here is a quick video I made tonight once it worked. You can't really hear it well, but you do get audio confirmation at each step like "How can I help you?" or whatever you want. I can post the codes if anyone is interested, but it is just a start.
[youtube]http://www.youtube.com/watch?v=eW6vhY4HfGo[/youtube]
Re: Listening Reef
please post code as you get it done. It is the crazy, neat stuff like this that sets RA so far ahead of it's competitors. I am constantly getting beat up on the forums by the close-minded Apex and other non-controller owners; but as that old song said, "and I just sit there smilin', sitting on that stack of code."
Thx RA community.
Ross
Maryland, USA
Thx RA community.
Ross
Maryland, USA
Re: Listening Reef
Cool! i want one too
- jsclownfish
Re: Listening Reef
Very cool. I can see all sorts of possibilities if the voice recognition is good enough.
- jsclownfish
Re: Listening Reef
I've finally got back to this fun little DIY addon. I've added new functionality like "feed the fish" with the autofeeder and "water change" which is kind of fun. I want to have a simple "default status" and an "all off" to control all the ports at once. I'm using this basic code (thanks Roberto!) now....
Is there an easier way to turn everything off or set everything to auto status without running through each port and setting them using masks?
Jon
GetVR();
if (vrrelay >0)
if (vrtype==0) // Turn port off
bitClear(ReefAngel.Relay.RelayMaskOn,vrrelay-1);
bitClear(ReefAngel.Relay.RelayMaskOff,vrrelay-1);
else if (vrtype==1) // Turn port on
bitSet(ReefAngel.Relay.RelayMaskOn,vrrelay-1);
bitSet(ReefAngel.Relay.RelayMaskOff,vrrelay-1);
else if (vrtype==2) // Turn port Auto
Jon
Re: Listening Reef
Try this:
ReefAngel.Relay.RelayMaskOn=0;
ReefAngel.Relay.RelayMaskOff=255;
- jsclownfish
Re: Listening Reef
Does that code for resetting the status to all auto settings or all off? (or one each?) I think I remember there was a function in the relay class of ReefAngel.Relay.AllOff that would turn everything off?
Jon
Jon
Re: Listening Reef
The code is to set everything back to auto.
You can use the AllOff to turn everything off, or go directly to the relay variable:
ReefAngel.Relay.RelayData=0;
