What is needed for Moonlights?
agentgreen
Post by agentgreen »
Hello,
I'm trying to piece together my controller, and one of the things I would like is the moonlights. I'm just not sure if I have enough equipment to do 2 moonlights.
I currently just have the main controller package with 1 relay box.
I'm looking at buying the Relay Expansion Module + Relay Box here shortly, plus an additional temperature probe.
Between the two relay boxes, do I have enough (or any) boosted PWM ports to plug up 2 moonlights?
Re: What is needed for Moonlights?
The main relay box you have can power 2 dimmable moonlights.
agentgreen
rimai wrote:The main relay box you have can power 2 dimmable moonlights.
Awesome, they just plug up to where the LEDs would?
Yes, you just plug them into each PWM output channel.
The expansion relay boxes will not add additional channels. To get more PWM channels, you will need a PWM expansion module.
agentgreen
Gotcha, all I need (at this point) is two.
