Another Wifi Config Problems
Re: Another Wifi Config Problems
First one was a thompson tg782 and now i use an old one 2wire 1800hg
Still without luck on this! the problem now its the modem/router config shows the rawifiatch stays inactive in the home network. any suggestion? i dont know if the problem its the router or someting.
Yes. I got IP address and follow all the steps to port forwarding and test it with ping in cmd but in the modem details shows me inactive device. That's the router or I need another thing in the controller?
Yes. I got ping
Ok, so what happens when you browse http://ipaddress:2000 ??
You may want to attach the wifi unit and "reset to factory defaults" and then start the process again since you switched routers. Just a thought, I had to do that when I changed mine. Are you on a mac or a pc?
Reefcam: dansreef.swanndvr.net login: guest pw: guest
its a PC. i already do that. I reset to factory settings when change the router and with the second one let me connect the attatchment and give me a valid ip. When I enter to the modem settings, i do the steps to port fowarding like the router manual said. The modem showns the wifi attatchment inactive. Im trying to find another router to make another test because i think the problem its the router. Do i need to change anything in the code?
ok i think i got this resolved. the portal update some info but now dont let me do anything. i think i change something in the ip of the portal and iphone app. i need to assign a public ip for this device?
Try and find a router that supports UPNP like a net gear or linksys. When you refer to your "modem" are you meaning the router?
Today I get the port forward complete and setup my wifi attachment. I said modem because here my connection it's DSL thru home phone jack and the modem got wifi router integrated.Badger55 wrote:Try and find a router that supports UPNP like a net gear or linksys. When you refer to your "modem" are you meaning the router?
I don't know why I put the public ip and port in my portal settings and get some info but don't let me do anything. It's said unreacheable address and don't let me use the ports toggles. Don't know what happens with that
When you check port 2000, does it say open?
If I check now with the phone says closed. But how the portal and iPhone app got that info? It's says my ph and my temprimai wrote:When you check port 2000, does it say open?
no luck with this. i follow all the steps to make the port foward, i already do everything but its says the port its closed. all the instructions with the modem, google sites, thomson manual, everything. what can i do?
I reboot the router and my ip changes too. Not the private ip, just the external ip.
This almost seems like you may need tech support from your DSL provider since it's an integrated router. I wish I could be more help but your setup is not something I'm used to dealing with. Maybe call them and explain what you are trying to do?
Hi, Finally i gets this working. Last night i called my ISP and talked with them about my configuration problems and they make me some changes in my configuration with my public ip because the company are making some upgrades in their services and their clients get some issues with the internet connection. The tech support employee says he make the changes but i need to wait for today to get the changes in order. I went to my house now in my lunch break and reset the router and looks working now. Hope this continue like now. Thanks to all. Now i can use the portal but my iphone app just show the parameters but the relay controls only shows updating and no response in it. i reinstall the app but still in updating screen, anyone know what happens in that?
If you switch back and forth between the two screens on the app they should be updated.
I did that but the relay ports screen still saying updating and no more. I tried several times and nothing!
No. Direct connect its off
If I turn it on, the main screen gets in updating too. I don't know if this takes part but my sketch when I did it in the wizard, I don't use the internal memory, only the code.
What's benefits or pros got do this in the internal memory?
