after //////rf programmed it stays in done
coolsilver
Post by coolsilver »
Hi
I just hooked up my new RA
I have quition in RF module
it was successufuly assigned as master to my 2 vortechs
with solid green LED it controlled both
but after that what should I do
the screen stays on :
assingning slaves
Done
how to continue ?
Load your new code.
coolsilver
Re: after //////rf programmed it stays in done
where I will find the new code ?
There is a wizard or you can go back to the preloaded code.
coolsilver
I went back to my configuration by uploading the sketch generated by wizard
the green LED turned into pink or white pink in the RF module
and it is not changing when trying to change modes from portal
same like beginning
coolsilver
what I did after hooking up RA+ controller
finished the wizard and uploaded it
finished the WIFI configuration and sucessufly connected the portal
now when I am trying to programm the RF module (I uploaded RA+ with vortechsetup )
RF module blinking green and blue
then make bothe vortechs as slaves (after reseting the memory for them )
press the joystick
RF module become GREEN
RA+ showing (assigne slave DONE )
after that uploaded the old wizard file and the green light in RA+ became pinky white
and tried to change the mode of vortechs from portal it didnt work
whad did I miss ?
Did you add any code to enable the RF in the original code?
coolsilver
I used the wizard and checked on RF
#include <Globals.h>
#include <RA_Wifi.h>
#include <Wire.h>
#include <OneWire.h>
#include <Time.h>
#include <DS1307RTC.h>
#include <InternalEEPROM.h>
#include <RA_NokiaLCD.h>
#include <RA_ATO.h>
#include <RA_Joystick.h>
#include <LED.h>
#include <RA_TempSensor.h>
#include <Relay.h>
#include <RA_PWM.h>
#include <Timer.h>
#include <Memory.h>
#include <RA_Colors.h>
#include <RA_CustomColors.h>
#include <Salinity.h>
#include <RF.h>
#include <IO.h>
#include <ORP.h>
#include <AI.h>
#include <PH.h>
#include <WaterLevel.h>
#include <ReefAngel.h>
    ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit;
    ReefAngel.FeedingModePortsE[0] = Port1Bit | Port2Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port7Bit;
    ReefAngel.WaterChangePortsE[0] = Port3Bit | Port4Bit;
    InternalMemory.OverheatTemp_write( 300 );
    ReefAngel.Relay.On( Port2 );
    ReefAngel.Relay.On( Port3 );
    ReefAngel.Relay.On( Port4 );
    ReefAngel.DosingPumpRepeat( Port5,0,1,10 );
    ReefAngel.StandardLights( Port6,18,0,0,0 );
    ReefAngel.Relay.DelayedOn( Port7,3 );
    ReefAngel.StandardFan( Port8,230,270 );
    ReefAngel.DosingPumpRepeat( Box1_Port5,0,60,60 );
    ReefAngel.DosingPumpRepeat( Box1_Port6,0,60,50 );
    ReefAngel.StandardATO( Box1_Port8,60 );
    ReefAngel.RF.SetMode( TidalSwell,100,10 );
    ReefAngel.Portal( "coolsilver" );
    int x,y;
#if defined DisplayLEDPWM && ! defined RemoveAllLights
    ReefAngel.LCD.DrawMonitor( 15, 10, ReefAngel.Params,
#else // defined DisplayLEDPWM && ! defined RemoveAllLights
    ReefAngel.LCD.DrawMonitor( 15, 10, ReefAngel.Params );
#endif // defined DisplayLEDPWM && ! defined RemoveAllLights
    // Salinity
    ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,15,46, "SAL:" );
    ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,39,46, ReefAngel.Params.Salinity );
    // Water Level
    ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,75,63, "WL:" );
    ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,99,63, ReefAngel.WaterLevel.GetLevel() );
    TempRelay &= ReefAngel.Relay.RelayMaskOff;
    TempRelay |= ReefAngel.Relay.RelayMaskOn;
    ReefAngel.LCD.DrawOutletBox( 12, 79, TempRelay );
    // Relay Expansion
    TempRelay = ReefAngel.Relay.RelayDataE[0];
    TempRelay &= ReefAngel.Relay.RelayMaskOffE[0];
    TempRelay |= ReefAngel.Relay.RelayMaskOnE[0];
    ReefAngel.LCD.DrawOutletBox( 12, 98, TempRelay );
You are hard coding it in your code to tidal swell at 100% with a 10 second duration.
Change usememory to true if you want to set via the portal.
The tidal swell mode shows as purple on the rf module.
coolsilver
thank you lnevo :idea:
you make me realize it it :D
I am able now to control it through portal I apritiate your support :D
