Question regarding the dosers.
pandimus
Post by pandimus »
Is there a way to set up the dosers so they will dose by ML, as opposed to time? for instance calibrate the pumps. I/e pump runs for 1min and it doses. 1 ML, then it is stored in memory so that i can use my android to set dosage, to 20ML a day. and later when i have more sps, just use my phone to increase it to 25ml..
Johnny
Re: Question regarding the dosers.
Yeah.
How many ml does your pump dispense in 100s?
pandimus
Post by pandimus »
Sorry i dont have pumps yet. Actually im still waiting on my reef angel to get here. I am just making some plans. There was an arduino doser that was on RC a while ago. i built it and programmed it. but did not buy pumps. Due to time constraints i bought a marine magic unit, but as other people have mention on here its a pain in the arse to program. When i want to add a second to one pumps interval. i have to input it like 35 times. i would like the ability to reprogram as easily as possible. But i was thinking i could Sell my marine magic, and Diy some pumps in some acrylic box's, and set up the RA to run them.
thanks
Johnny.
PS. i bought a used RA. it is analog, can it be changed to PWM?
Yes, it can be changed to PWM, but if it is not the latest revision, you will need to send it back or DIY with a soldering iron.
pandimus
Post by pandimus »
Thanks.do you have a link for the diy mod?
Can you take a photo of the inside of your relay box?
pandimus
Post by pandimus »
I get it Tuesday.I will then.Thanks for all the help.
pandimus
Post by pandimus »
It's it just top four screws then pry?
yeap
pandimus
Post by pandimus »
Is that enough?
I don't think that box is analog.
Does it have a sticker on the bottom of the box?
pandimus
Post by pandimus »
No stickers at all the guy I bought it from said it was analog.
It's PWM already.
pandimus
Post by pandimus »
Excellent.thanks
tang185
Post by tang185 »
Any word on when the RA dosers will be back in stock?
1 to 2 weeks.
tang185
Post by tang185 »
Cool, thanks. I bought a marine magic 3-part doser and having finally penetrated the almost incomprehensible directions, I find that I would have to make some 26 program changes just to increase or decrease the amount of calc, alk or vinegar I want to dose. I figure if I do it with the Reef Angel dosers, I may find time to finally finish reading War & Peace.
pandimus
Post by pandimus »
Yeah I'm selling my marine magic for the same reason.
