I couldn't get the firmware to update via wifi utility. This is the error:
Connected to serial port COM6
< CMD
> ftp u
< ftp u
< <4.00>
< FTP connecting to 198.175.253.161
< FTP file=56:...............................................................
< UPDATE OK
< FTP OK.
> ftp r wps.img
< ftp r wps.img
< <4.00>
< 550 wps.img: The system cannot find the file specified.
< FTP ERR
Removing connection to COM6
Do I "need" the firware updated in order for it to work? I just received the wifi unit yesterday so it's new.
When I point my browser to the IP indicated in the wifi utility (192.168.2.10:2000) I get "No data received
Unable to load the webpage because the server sent no data." from chrome. But if I ping, it's OK.
I started with older version of library, so I updated everything and tried again.. and again, still no luck. Version on RA menu is 1.0.3 and WDT on the next line.
Any ideas? Thanks.
