cjrudy
Posts: 135 Joined: Sat Nov 10, 2012 2:47 pm
Post
by cjrudy » Tue Apr 23, 2013 4:42 pm
Does anyone know the max head for this pump ?
Posts: 12881 Joined: Fri Mar 18, 2011 6:47 pm
Post
by rimai » Tue Apr 23, 2013 4:51 pm
You should be able to get 6 feet without loss
Sebyte
Post
by Sebyte » Tue Apr 23, 2013 4:56 pm
I was pumping over 10ft from the basement to the first floor before I installed the sump in the basement. Obviously the flow was reduced but still usable.
cjrudy
Post
by cjrudy » Tue Apr 23, 2013 4:59 pm
That should work, need an alternative to my Aqualifter, about the same ml per minute but the aqualifter max head is 30"
Sebyte
Post
by Sebyte » Thu Apr 25, 2013 2:54 pm
The flow at 10ft was much better than the Aqualifter at 3ft.
cjrudy
Post
by cjrudy » Sat Apr 27, 2013 12:55 pm
I got the pump, seems to work well but wow, is it loud, really loud. Also seems cheaply made but as long as it works.
Not sure I will be able to stand the noise though.
