I've had some issues with my buttons on the IO module and while troubleshooting I realized that I need some sort of "debounce" for the button presses. I'm pretty sure I have that all sorted out but that led me to a couple of schematics that make me think I'm going about the buttons all wrong and wanted to run this by you.
From my Arduino/Electrical newb-ness, I pictured the buttons I am using with the I/O module as simply completing the circuit between the port it's plugged into (0-6) and the ground on the module. I am not using any resistors this way.
Here is what is making me second guess that:
Looking at the schematics above, it looks like I should be plugging the +5v from the Arduino board into one side of the button and go to ground via a resistor on the other side. I would tie in the I/O pin on the resistor side of the button to check if I'm HIGH or LOW.
Sorry for the nomenclature but I'm still an electronics newb and don't know how to properly phrase that. I hope you can get the gist of what I'm saying.
Am I OK doing it my way I have been doing it? It has been working fine other than that odd button behavior that the debounce should fix.
[EDIT]
Or are you already taking care of that under the hood on the module?
[/EDIT]
~Charlie
