Wifi firmware update problem
Re: Wifi firmware update problem
It's probably that you are trying to use the old ftp server.
The new one is rn.microchip.com, which resolves to 198.175.253.161.
use this command to update the ftp address:
set f a 198.175.253.161
Thanks - will give it a shotrimai wrote:It's probably that you are trying to use the old ftp server.
I did what you suggested
Give it another shot...
The first 2 looks like the wifi wasn't connected...
The AUTH-ERR shown in the log tells that the wifi was not connected properly.
The 3rd one was issued mid way into the authentication process.
Thanks roberto, seems to have mostly fixed it.
Now i am getting this when i try run "ftp update wifly3-400.mif"
After you do the 1st ftp u for the .img file, you must save and reboot then do the 2nd ftp u with the .mif file.
Thanks can I ask what is the command for save and reboot?rimai wrote:After you do the 1st ftp u for the .img file, you must save and reboot then do the 2nd ftp u with the .mif file.
Is it just "save" and "reboot"?
I have succesfully performed the updates and using the graphical wifi utility (mac) have connected to my network.rimai wrote:yeap
However, after connecting the wifi unit back to my reefangel and trying to browse to it in my web browser (192.168.0.15:2000/wifi) i get a message saying "no data received"
I can ping the unit and have confirmed it is on the network through the router monitoring tools. i feel like it needs the reefangel software/firmware installed on it?
Lights were flashing on it. Yellow I thinkrimai wrote:Did you check wifi attachment when generating the code?
Ok, but does your code have wifi stuff?
You must either check mark wifi attachment on the wizard when generating or add it later.
Can you post your code?
My code should have wifi....rimai wrote:Ok, but does your code have wifi stuff?
Edit - Attached codes
- Memory.ino
- (1.15 KiB) Downloaded 331 times
- Binder_Homescreen.ino
- Main Code
- (4.71 KiB) Downloaded 328 times
I don't see wifi stuff in there.
Make sure to add this right above ShowInterface();
ReefAngel.Portal("Poiromaniax");
