Wifi firmware update problem
Lights were flashing on it. Yellow I thinkrimai wrote:Did you check wifi attachment when generating the code?
Re: Wifi firmware update problem
Ok, but does your code have wifi stuff?
You must either check mark wifi attachment on the wizard when generating or add it later.
Can you post your code?
My code should have wifi....rimai wrote:Ok, but does your code have wifi stuff?
Edit - Attached codes
- Memory.ino
- (1.15 KiB) Downloaded 331 times
- Binder_Homescreen.ino
- Main Code
- (4.71 KiB) Downloaded 328 times
I don't see wifi stuff in there.
Make sure to add this right above ShowInterface();
ReefAngel.Portal("Poiromaniax");
