I was hoping the latest firmware upgrade to 4.0 would finally solve the wifi issues once and for all, but I guess not.
I upgrade the firmware a week ago and have had to reboot the wifi at least 3-4 times.
At least with the older firmware it only needed to reboot a few times a month, maybe I need to downgrade.
WiFi Problems ...Again!!
- DrewPalmer04
Re: WiFi Problems ...Again!!
Or Ethernet and cheap ddwrt router repeater bridge
Could it be the router?
I've heard of some other users that had problems with some routers and not with other ones.
Also, make sure you are using WPA2-PSK with AES encryption.
Can you post the "get e" dump?
I can post get e later when I get home.
The router is a new netgear, I doubt that's the issue considering I had less issues with the older firmware
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2013.05.22 06:53:51 =~=~=~=~=~=~=~=~=~=~=~=
<4.00> get e
wifly-GSX Ver 4.00.1, Apr 19 2013 11:48:31 on RN-131
Beacon=100
Reboot=0
IF=UP
DHCP=ON
IP=10.0.0.2:2000
NM=255.255.255.0
GW=10.0.0.1
HOST=198.171.134.6:80
PROTO=TCP,
MTU=1524
FLAGS=0x6
TCPMODE=0x0
BACKUP=0.0.0.0
OPEN=
CLOSE=
REMOTE=
FlushSize=1420
MatchChar=0
FlushTimer=10
IdleTimer=3
CmdChar=$
DNS=10.0.0.1
Name=www.reefangel.com
Backup=backup2
Lease=300
FTP=198.175.253.161:21
File=wifly-GSX.img
User=roving
Pass=Pass123
Dir=public
Timeout=80
FTP_mode=0x0
SSID=NETGEAR07
Chan=0
ExtAnt=0
Join=1
Auth=OPEN
Mask=0x1fff
Rate=12, 24 Mb
Linkmon-Infra=5
Linkmon-AP=0
Passphrase=xxxxxxxxxxxxxxx
EAP_Id=
EAP_User=
SleepTmr=0
WakeTmr=0
Trigger=0x10
Autoconn=0
IoFunc=0x0
IoMask=0x20f0
IoValu=0x0
DebugReg=0x0
PrintLvl=0x0
LaunchStr=
TimeEna=0
TIMEADR=129.6.15.28:123
Zone=7
Baudrate=57600
Flow=0x0
Mode=0x2
Cmd_GPIO=0
<4.00> get e
Beacon=100
Reboot=0
IF=UP
DHCP=ON
IP=10.0.0.2:2000
NM=255.255.255.0
GW=10.0.0.1
PROTO=TCP,
MTU=1524
FLAGS=0x6
TCPMODE=0x0
BACKUP=0.0.0.0
OPEN=
CLOSE=
REMOTE=
FlushSize=1420
MatchChar=0
FlushTimer=10
IdleTimer=3
CmdChar=$
DNS=10.0.0.1
Backup=backup2
Lease=300
File=wifly-GSX.img
User=roving
Pass=Pass123
Dir=public
Timeout=80
FTP_mode=0x0
SSID=NETGEAR07
Chan=0
ExtAnt=0
Join=1
Auth=OPEN
Mask=0x1fff
Rate=12, 24 Mb
Linkmon-Infra=5
Linkmon-AP=0
EAP_Id=
EAP_User=
SleepTmr=0
WakeTmr=0
Trigger=0x10
Autoconn=0
IoFunc=0x0
IoMask=0x20f0
IoValu=0x0
DebugReg=0x0
PrintLvl=0x0
LaunchStr=
TimeEna=0
Zone=7
Baudrate=57600
Flow=0x0
Mode=0x2
Cmd_GPIO=0
Yeah, I don't see anything wrong with it.
Are you using WPA2-PSK with AES encryption?
