Wifi setup fail
Re: Wifi setup fail
Sorry guys I'm coming from a ACjr to this.
This the code? I didn't save the one from the utility.
ReefAngel.WaterChangePorts = Port3Bit | Port4Bit | Port6Bit | Port8Bit;
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port5 );
ReefAngel.StandardHeater( Port2,776,780 );
ReefAngel.Relay.DelayedOn( Port4,10 );
ReefAngel.Relay.DelayedOn( Port7,10 );
ReefAngel.Relay.DelayedOn( Port8,10 );
ReefAngel.Portal( "hibb304" );
int x,y;
ReefAngel.LCD.DrawMonitor( 15, 14, ReefAngel.Params,
ReefAngel.LCD.DrawMonitor( 15, 14, ReefAngel.Params );
// pH Expansion
ReefAngel.LCD.DrawText( COLOR_MEDIUMSEAGREEN,DefaultBGColor,15,54, "PHE:" );
ReefAngel.LCD.DrawSingleMonitor( ReefAngel.Params.PHExp,COLOR_DARKKHAKI,39,54, 100 );
ReefAngel.LCD.DrawOutletBox( 12, 74, TempRelay );
// Relay Expansion
ReefAngel.LCD.DrawOutletBox( 12, 97, TempRelay );
int x,y;
// pH Expansion
// Relay Expansion
Re: Wifi setup fail
Yes, that's code.
Make sure you uploaded it to the controller and that you have the wifi attachment connected to the controller.
Re: Wifi setup fail
I finally got guys. Had to re upload to the controller re hooked up the wifi to it, and boom it works.
Thanks again, y'all been great.
Re: Wifi setup fail
Ok it still works I did a no IP address, but still cant use the app on my wifi. I got t turn it to 3g to use. Any ideas?
Re: Wifi setup fail
What type of router are you using?
Re: Wifi setup fail
Could it be because your router doesn't implement NAT loopback?
I seem to see this happening now and then.
I have this same problem myself, because my router doesn't do it either.
Re: Wifi setup fail
Really damn. Anyone recommend a router modem combo. I do have another wireless router. Can that be hooked up to a router/modem too?
