thekameleon wrote:Does anyone know if these LDD drivers offer deep diming or basically being able to dim the light output to zero. Instead of the 50 to 100% that the ELN drivers seem to do.
I haven't tried them, but I have been told by people that do use them that they will go right down to zero so you can dim below the usual 10% cutoff. I should have about 6 channels up this fall using them.
Fat
+1
They go right to zero, the advantage of that is freeing up a at least two ports on my relay box.
You say down to zero, so that applies to output as well. With my Meanwell drivers, when I apply 10% the LEDs seem to be at 50% brightness already. So with the LDD at 10% at the input will I have 10% brightness?
