WiFi Attachment Setup Issue
Re: WiFi Attachment Setup Issue
Works fine with windows.
Ok, so after investigating this for a while, I noticed that it has to do with specific settings in your local MacOSX machine.
Here is the thread that led me to a work around:
http://forum.arduino.cc/index.php?topic ... msg1016859
You basically need to run two commands in sudo mode:
I remember reading somewhere that there is a version that doesn't use locks and you don't need to run those commands. I just need to figure out how.
I'll try to find a more permanent solution.To use the serial library, first open
Applications -> Utilities -> Terminal.app
and enter the following:
sudo mkdir -p /var/lock
sudo chmod 777 /var/lock
I have recompiled using a processing 1.5.1 instead of the current released one.
Can anyone with a Mac try this version to see if it works before I package in the installer?
http://www.reefangel.com/files/wifi_uti ... _1.06a.zip
Yes this version works on mac (I have snow leopard), I just tried it.
