Can't upload anything
Blawson
Post by Blawson »
I have had my RA+ for a year and I am trying to update my code. I keep getting errors everytime i try to upload anything:
Watchdog Timer
Version Menu
Simple Menu
Binary sketch size: 19,040 bytes (of a 258,048 byte maximum)
C:\Program Files\Reef Angel Controller\hardware/tools/avr/bin/avrdude -CC:\Program Files\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega2560 -cstk500v2 -P\\.\COM4 -b115200 -D -Uflash:w:C:\Users\Home\AppData\Local\Temp\build3790747732963479285.tmp\InitialInternalMemory.cpp.hex:i
System wide configuration file is "C:\Program Files\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf"
Using Port : \\.\COM4
Using Programmer : stk500v2
Overriding Baud Rate : 115200
avrdude: Send: . [1b] . [01] . [00] . [01] . [0e] . [01] . [14]
avrdude: Recv:
avrdude done. Thank you.
The RA reboots during the upload and then I get the error.
Help please...
Re: Can't upload anything
Black wire on the ttl cable all the way to the right? No empty pins on the right side?
Sent from my HTC One X using Tapatalk 4 Beta
Blawson
Post by Blawson »
yes. I am going through uninstall and reinstall right now. cable is plugged in correctly
Blawson
Post by Blawson »
That did not work. Same error.
Blawson
Post by Blawson »
OK - I changed from RA+ to Ra with bootloader and it worked... Go Figure.
Now my dimming module is not working... It is on - reading the manual it says I need to upload the PMW code - but isnt that already in the Wizard when I put that together?
Blawson
Post by Blawson »
and before anyone asks... Here's the code:
ReefAngel.FeedingModePorts = Port4Bit | Port6Bit | Port7Bit;
ReefAngel.WaterChangePorts = Port4Bit | Port5Bit | Port6Bit | Port7Bit;
ReefAngel.Relay.On( Port7 );
ReefAngel.DosingPumpRepeat( Port1,0,60,10 );
ReefAngel.DosingPumpRepeat( Port2,0,60,10 );
ReefAngel.StandardLights( Port3,9,30,22,30 );
ReefAngel.Relay.DelayedOn( Port4,10 );
ReefAngel.StandardHeater( Port5,795,805 );
ReefAngel.Relay.Set( Port8, !ReefAngel.Relay.Status( Port3 ) );
ReefAngel.PWM.SetChannel( 0, PWMSlope(10,0,22,0,10,50,120,10) );
ReefAngel.PWM.SetChannel( 1, PWMSlope(10,30,21,30,0,40,120,0) );
ReefAngel.PWM.SetChannel( 2, PWMSlope(10,30,21,30,0,30,120,0) );
ReefAngel.PWM.SetChannel( 3, PWMSlope(10,30,21,30,0,30,120,0) );
ReefAngel.Portal( "blawson" );
int x,y;
// Dimming Expansion
x = 15;
y = 2;
for ( int a=0;a<6;a++ )
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
When you say not working, how do you mean? Values don't change? Lights don't come on?
Blawson
Post by Blawson »
Lights all come on. Values change on the controller and portal but change in intensity from the lights.
Was this working before the update?
Blawson
Post by Blawson »
I just added the dimming module. The RA was working fine before that. I had an AI running and it dimmed one but that was just from the head unit.
I should probably clarify. I originally bought the RA PMW unit a little over a year ago. I upgraded to the RA plus after that. I Just bought and added the dimming module (PMW) and built a new led array for it.
I got the uploading issue fixed and now have the wizard code uploaded. All lights come on but do not dim. The dimming shows on the screen and the portal. I did the internal memory so I can adjust without a new upload.
I checked and double checked to make sure all the cables were plugged in correctly.
Can you check the output voltage on the dimming module without your drivers?
Sent from my SPH-L710 using Tapatalk 4 Beta
Blawson
Post by Blawson »
I can but not sure how. Would I just use a multi meter?
yes
Blawson
Post by Blawson »
K. I will check it out and post back.
Blawson
Post by Blawson »
OK - I have to pick up a multi meter (didnt have time today)
In the meantime, I put code in to use the dimming ports on the original box but the problem is that the driver I have only uses 1 wire for dimming... The port has a + and -.
Any suggestions on wiring that puppy? Can't find anything on it.
Blawson
Post by Blawson »
I got it! Wiring issue - dimming expansion seems to be working. I will get it all wired back up and let you know.
