Can you check the output voltage on the dimming module without your drivers?
Sent from my SPH-L710 using Tapatalk 4 Beta
Can't upload anything
Re: Can't upload anything
I can but not sure how. Would I just use a multi meter?
K. I will check it out and post back.
OK - I have to pick up a multi meter (didnt have time today)
In the meantime, I put code in to use the dimming ports on the original box but the problem is that the driver I have only uses 1 wire for dimming... The port has a + and -.
Any suggestions on wiring that puppy? Can't find anything on it.
I got it! Wiring issue - dimming expansion seems to be working. I will get it all wired back up and let you know.
