wifi 0.0.0.0:2000 address
Re: wifi 0.0.0.0:2000 address
the only other thing i can think of is the cable connected to the module correctly, as per step 2.
or maybe try using putty or hyperterminal to connect.
Thanks for your help Appleseed. I was monkeying around with and it looks like I finally got an IP address. I'm going to run through the rest of setup to see how things go. Thanks again.
Looks good so far. Minus the port forwarding. I opened it on my router (D-Link) but is doesn't seem to be open when checked on http://www.yougetsignal.com/tools/open-ports/ even after I restarted the router. Did you get yours to properly forward (I know its router specific though)?
my port forwarding works fine, can you ping your module.
Yeah I can ping it.
I now get OPEN Port confirmation (2000) from canyouseeme.org. YAY! However, portal still shows address unreachable.
I had to reserve the IP assigned to the wifi attachment to make sure it didn't change when rebooting my router.
I verified that the port is open.
I can turn on/off ports via wifi on the RA Client.
I verified that the key is correct in code and uploaded to the RA
I still get Connect Status: Unreachable address
iPhone app won't refresh.
Can someone please help? Thanks.
Jeremiah
Jeremiah
<sigh> This is frustrating. Everything was working aside from Portal. I wanted to verify that portal key was loaded properly so launched Arduino and was prompted to update to 1.0.9 (from 1.0.6). I updated hoping it would help solve any "other" issues. Now I can't connect to RA Client via wifi anymore.
...back to square one...
Sure. RA Client is running again. Issues are still with Portal (Unreachable Address).
Reconfirmed that port 2000 is open via Canyouseeme.org
Thanks Roberto.
ReefAngel.FeedingModePorts = Port2Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port4Bit;
ReefAngel.LightsOnPorts = Port8Bit;
ReefAngel.LightsOnPortsE[0] = Port4Bit;
ReefAngel.OverheatShutoffPortsE[0] = Port1Bit | Port2Bit | Port3Bit;
ReefAngel.Relay.On( Port2 );
ReefAngel.StandardLights( Port3,9,0,19,0 );
ReefAngel.StandardHeater( Port4,751,771 );
ReefAngel.StandardLights( Port5,9,0,15,30 );
ReefAngel.StandardLights( Port6,15,0,21,0 );
ReefAngel.StandardFan( Port7,771,781 );
ReefAngel.StandardLights( Port8,9,0,21,0 );
ReefAngel.MHLights( Box1_Port1,13,0,18,0,5 );
ReefAngel.MHLights( Box1_Port2,13,0,18,0,5 );
ReefAngel.MHLights( Box1_Port3,13,0,18,0,5 );
ReefAngel.StandardLights( Box1_Port4,11,0,20,0 );
ReefAngel.StandardLights( Box1_Port5,12,0,21,0 );
ReefAngel.StandardLights( Box1_Port6,21,0,2,0 );
ReefAngel.DosingPumpRepeat( Box1_Port7,0,60,10 );
ReefAngel.PWM.SetChannel( 0, MoonPhase() );
ReefAngel.RF.SetMode( Constant,50,10 );
ReefAngel.Portal("mylogin","mypassword");
int x,y;
// Dimming Expansion
x = 15;
y = 2;
for ( int a=0;a<6;a++ )
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
ReefAngel.LCD.DrawMonitor( 15, 35, ReefAngel.Params,
ReefAngel.LCD.DrawMonitor( 15, 35, ReefAngel.Params );
// pH Expansion
ReefAngel.LCD.DrawText( COLOR_MEDIUMSEAGREEN,DefaultBGColor,15,68, "PHE:" );
ReefAngel.LCD.DrawText( COLOR_MEDIUMSEAGREEN,DefaultBGColor,39,68, ReefAngel.Params.PHExp );
// Water Level
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,75,68, "WL:" );
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,99,68, ReefAngel.WaterLevel.GetLevel() );
ReefAngel.LCD.DrawOutletBox( 12, 81, TempRelay );
// Relay Expansion
ReefAngel.LCD.DrawOutletBox( 12, 97, TempRelay );
Thanks Roberto.
According to your webbanner, the server is receiving data.
Last update was less than 5 min ago.
What happens when you click the ip address on the portal page?
I get URL can't be shown on iPad. And a timeout from my computer.
Banner updates but the other features say I need a valid ip address (Internal memory, date and time, etc.)
If you can't connect using wan ip address, the portal can't either.
There is still something not working right with the port forwarding.
Is there something I can test to isolate the issue? All the port forwarding check site show that the port is open. Thanks Roberto.
Hey Roberto. It's working now. Thanks for help. You asking me to click on my the IP address prompted me to take a "real" look at it. The IP always updated automatically when my router got assigned a new Dynamic IP so I assumed all was well. Turns out that it was missing the port information under User Control Panel --> Profile --> WiFi Address. So even though the IP was correct and updating it was not complete. Now things seem fine. Thanks again.
Jeremiah
Jeremiah
