My Jebao "Else" mode
UPDATE: Sync and anti-sync added. Someone please test for me as I only have one pump.
I really like the "Else" mode on the Jebao stock controller. It has lots of swings with a wide range of speeds. It's not truly random, but a long, complex sequence. My version is more random.
Call with ElseMode( MidPoint, Offset, Sync );
Where Midpoint is the middle of the range you want, and Offset is the +/- range. Sync and anti-sync are opposites (true for sync or false for anti-sync) For example, ElseMode ( 70, 30, true ) will return values from 40% to 100%. The speed changes every 0.5 to 5 seconds and can be anywhere in between MidPoint +/- Offset.
  static unsigned long LastChange=millis();        // Set the inital time that the last change occurred
  static int Delay = random( 500, 3000);           // Set the initial delay
  static int NewSpeed = MidPoint;                  // Set the initial speed
  static int AntiSpeed = MidPoint;                 // Set the initial anti sync speed
  if ((millis()-LastChange) > Delay)               // Check if the delay has elapsed
    Delay=random(500,5000);                        // If so, come up with a new delay
    int ChangeUp = random(Offset);                 // Amount to go up or down
    if (random(100)<50)                            // 50/50 chance of speed going up or going down
    LastChange=millis();                           // Reset the time of the last change
  if (WaveSync)
    return NewSpeed;
    return AntiSpeed;
avionixx
Re: My Jebao "Else" mode
Post by avionixx »
Nice! I can't wait to try this later!
jjdezek
Post by jjdezek »
is there anything you have to change to make it work? i copied and pasted it into the place custom code here and it gave an error on the first {
Put it at the very end of everything, past and outside of loop(). Then call like any other wave function.
jjdezek
Post by jjdezek »
can i set it up to be the custom setting under the portal?
I think so. I don't have WiFi on this tank so I can't test it.
Sent from my M470BSA using Tapatalk 4 Beta
jjdezek
Post by jjdezek »
how would i go about trying that? the last custom code for the jeabo i had to put into the place custom code here and when i selected custom on the portal it would use that code. would i just put some call code in the place custom code here?
Post your old code that worked before.
ReeferBee
Post by ReeferBee »
Thank you! Can't wait to try it out.
Barry
Current tank info: 150g mixed reef
"Some of the worst mistakes of my life were hair cuts" -Jim Morrison
jjdezek
Post by jjdezek »
this is what im using right now.
#define NUMBERS_8x16
ReefAngel.LCD.DrawText(COLOR_INDIGO, COLOR_WHITE,25,5, "Jeremy's Reef");
DrawStatus (20,80);
DrawParams (5,40);
DrawParamsa (0,10);
    ReefAngel.WaterChangePorts = Port1Bit;
    ReefAngel.OverheatShutoffPorts = Port3Bit | Port7Bit;
    ReefAngel.Relay.On( Port2 );
    ReefAngel.Relay.On( Port4 );
    ReefAngel.StandardATO( Port1,60 );
    ReefAngel.StandardLights( Port3,18,0,10,0 );
    ReefAngel.Wavemaker( Port5,60 );
    ReefAngel.Wavemaker( Port6,60 );
    ReefAngel.StandardHeater( Port7,751,761 );
      if (ReefAngel.DCPump.Mode==Custom)
  ReefAngel.PWM.SetDaylight( NutrientTransportMode(50,100,2000,true) ); // Nutrient Transport on sync mode
  ReefAngel.PWM.SetActinic( NutrientTransportMode(50,100,2000,false) ); // Nutrient Transport on anti-sync mode
    ReefAngel.Portal( "jjdezek" );
void DrawParamsa(int x, int y){
char buf[16];
  ReefAngel.LCD.DrawText(DPColor,DefaultBGColor,x+40,y+10,"WP40L:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetDaylightValue(), DPColor, x+78, y+10,1);
ReefAngel.LCD.DrawText(APColor,DefaultBGColor,x+40,y+20,"WP40R:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetActinicValue(),APColor, x+78, y+20,1);
  char buf[16];
  // Temp and PH
  y+=10;
  y+=5;
  int t=x;
jjdezek wrote:this is what im using right now.
Try this:
DrawStatus (20,80);
DrawParams (5,40);
DrawParamsa (0,10);
  ReefAngel.PWM.SetDaylight( ElseMode(70,30,true ));                     // ElseMode on sync mode, 70 +/- 30%
  ReefAngel.PWM.SetActinic( ElseMode(70,30,false ));                     // ElseMode on anti-sync mode, 70 +/- 30%
char buf[16];
  char buf[16];
  // Temp and PH
  y+=10;
  y+=5;
  int t=x;
  if (WaveSync)
    return NewSpeed;
    return AntiSpeed;
jjdezek
Post by jjdezek »
cool thanks for the help. got it working.
bhazard
Post by bhazard »
Can't wait to try it. A good else mode is the only thing missing for the Jebao pumps. ELSE and W1 were the only two modes I used.
bhazard
Post by bhazard »
Ok, I really like this one. Its very close to ELSE and more random.
Smotz
Post by Smotz »
Thanks for this - I will try soon!
Thanks Collin.
I'm going to try this over the weekend.
Glad you guys like it!
Sent from my HTC One X using Tapatalk 4 Beta
Added to my random rotation :)
Collin;
Can this code work properly with just 1 pump?
jjdezek
Post by jjdezek »
that's all I have is one pump and it seems to work fine. just don't have anything plugged into the actinic port.
Thanks;
I just tried it and it seemed to stay at 20%.
  ReefAngel.PWM.SetActinic( ElseMode(60,20,true ));                     // ElseMode on sync mode, 60 +/- 20%
Do you have any lights port overridden?
No I did not.
I have currently switched my code back to what was working, but at the time there were no overridden lights or anything out of the norm.
Sacohen wrote:Collin;
Yep. I use it with a single pump. I have no idea why it wouldn't work for you. Should be fairly straightforward.
You need to do ReefAngel.DCPump.UseMemory=false; and then set it back to true when its not custom mode.
Nevermind, no you don't.. I just re-read what you said.
Can you post your code.. Your probably overriding it somewhere...
Here you go...
unsigned long ATOUpdate=0;
ReefAngel.WaterChangePorts = Port4Bit | Port6Bit;
//Set Standard Menu
ReefAngel.AddStandardMenu();
ReefAngel.StandardLights( Port1,12,0,22,0 );
ReefAngel.StandardLights( Port2,13,0,21,0 );
ReefAngel.Relay.Set( Port3, !ReefAngel.Relay.Status( Port1 ) );
ReefAngel.StandardLights( Port7,13,0,21,0 );
ReefAngel.Relay.Set(Port5,(now()-3600)%21600<1200); // Runs for 1200s every 21600 seconds
ReefAngel.Relay.Set(Port8,((now()-3600)-1200)%21600<1200); // Runs for 1200s every 21600 seconds with 1200s offset
ReefAngel.WaterLevelATO(Port6,720,30,30); // Enable ATO the ATO
if (ReefAngel.Relay.Status(Port5)) // Check to see if port 5 is on and update time is empty
ATOUpdate = now(); // If so, set the update time to now
if (now() - ATOUpdate < 120) // If it hasnt been 120 seconds turn off the port
ReefAngel.WaterLevelATO(Port6,720,0,1);
if (hour()<12 || hour()>=22) ReefAngel.PWM.SetActinic(30);
ReefAngel.Portal( "Sacohen","Seth0310" );
int x,y;
// Water Level
  if (WaveSync)
    return NewSpeed;
    return AntiSpeed;
It seems to be working right now.
The PWM Channel is showing a change in the speed, is the DC Pump section?
That stays at 30%.
Thanks.
Because your bypassing the dc pump in custom mode..
What i would do is pass the dcpump speed to the elsemode function so you can adjust the else mode by how you set the dcpump in the portal.
How would you code that?
I looked at your Complete PDE and it doesn't look like you've updated it to include the DCPump.mode and Collins was written as I have it.
