SO what I want to do is have this else mode on during the day 0600-2000 = 45% +/- 15
and else mode at night 2000 - 0600 = 35% +/- 5%
I have reefbreeders LEDs and they have their own controller so i do not have the lights on a schedule so i am not sure which dimming switch to plug the jebao into. or if it matters.
I have port 5 as my extra power head on during the day
and port 6 is where I will plug my jebao into.
here is my wizard drafted code.
I have not added in the else mode code yet cause i dont completely understand how the actinic / daylight section works or the schedule I want.
Thank you in advance
EDIT: I found some other threads with schedules in them and got them working. however I uploaded my code but both my dimming channels are at 0% right now even though it should be on else mode.
ideas?
ReefAngel.FeedingModePorts = Port1Bit | Port3Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port3Bit | Port7Bit | Port8Bit;
ReefAngel.Relay.On( Port2 );
ReefAngel.Relay.On( Port7 );
ReefAngel.StandardHeater( Port3,771,775 );
ReefAngel.StandardLights( Port4,20,0,8,0 );
ReefAngel.Relay.Set( Port5, !ReefAngel.Relay.Status( Port4 ) );
ReefAngel.StandardFan( Port8,775,780 );
ReefAngel.DCPump.SetMode( ShortPulse,40,30 );
if (ReefAngel.DCPump.Mode==Custom)
if ( (now()%SECS_PER_DAY >= 28800) || (now()%SECS_PER_DAY<= 72000) ) //0800-2000
ReefAngel.PWM.SetActinic( ElseMode(45,15,true)); //
else if ( (now()%SECS_PER_DAY >= 72000) && (now()%SECS_PER_DAY<= 28800) )
ReefAngel.PWM.SetActinic( ElseMode(35,5,true)); // Else on sync mode, 36 +/- 6%
ReefAngel.Portal( "iratefrizz" );
if (WaveSync)
return NewSpeed;
return AntiSpeed;
