WP40 issue
WP40 issue
I woke up this morning and went to feed my fish and noticed there wasn't much current in my tank. Looked over and my WP40 wasn't on so I checked to see if it maybe came unhooked, it was fine. I plugged into actinic port to see if it was that port and nothing. I pulled the wave maker out took it apart cleaned the fan magnet(bad idea now its noisy) still got nothing. So I unhooked it from RA and connected it back up to the original controller and bam it works. Anyone else have this problem. Codes still showing ports are on and running but its not powering the WP40.
Re: WP40 issue
Must of had a loose connection somewhere. Hooked it back up and its working. Wierd
Re: WP40 issue
Fine is often finicky, also. Especially if I set the power below 30%. I sometimes have to power cycle it many times to get it going.jjdezek wrote:Must of had a loose connection somewhere. Hooked it back up and its working. Wierd
