RF Expansion Module
Deckoz2302
Re: RF Expansion Module
Post by Deckoz2302 »
i know this might sound silly but...I was thinking how do you set the initial internal memory values, so i opened up the manual and it directs you to the download page to download VortechSetup.pde....however i dont see that on the downloadpage :/
So sorry, I forgot to update the page.
It's updated now.
http://www.reefangel.com/Download.ashx
Deckoz2302
Haha no prob roberto, lol it happens to the best of us. Thanks. And just a side note - I love the capabilities and flexibility of this controller. I get to spend more time watching and less time doing - the value of having things do what you want at the push of a button and be exactly how you want it is amazing(had a rke before and didn't like the gerneralized prewrtten programs)
StuGotz
Post by StuGotz »
What about adding a new function to check stormchance and be able to limit the amount of times a storm can occur, so it doesn't storm every time it gets cloudy?
The function already had that chance feature.
Look for this line:
StuGotz
Post by StuGotz »
Got my RF Module today! I went to compile and upload VortechSetup.pde from the download page, but it's giving me a compile error.
..\Documents\Arduino\libraries\ReefAngel_CustomColors/ReefAngel_CustomColors.h:20:30: error: ReefAngel_Colors.h: No such file or directory
It should be ..\My Documents\Arduino.... I don't have this problem compiling and uploading my normal PDE. Any suggestions?
Seems like you are missing libraries.
It's looking for a file ReefAngel_Colors.h, which should be under "Document\Arduino\libraries\ReefAngel_Colors" folder.
Do you have that folder?
Maybe you should update the libraries just in case.
http://www.reefangel.com/update
StuGotz
Post by StuGotz »
I have that folder under "My Documents\Arduino\libraries\ReefAngel_Colors" not "Document\Arduino\libraries\ReefAngel_Colors. I've modified it to change the default temp colors for my main PDE a couple weeks ago, and compiles fine for my normal PDE.
Can I see your features file?
StuGotz
Post by StuGotz »
#define DisplayLEDPWM
#define wifi
#define VersionMenu
#define CUSTOM_MAIN
#define NUMBERS_8x16
#define COLORS_PDE
#define CUSTOM_MENU
#define CUSTOM_MENU_ENTRIES 7
#define RFEXPANSION
Found the problem.
It had missing includes on the PDE file.
I uploaded a corrected version.
Please go ahead and download it again.
StuGotz
Post by StuGotz »
That did it. As always you never cease to amaze me on how quick you respond!
So if after I "Press the joystick to finalize your pump setup" the vortech goes white, but the module keeps flashing blue and green do I have to try to sync them again?
Deckoz2302
When you did it did you clear your vortech memory first? Also - in yoru setup() define the mode you want to use constantly, then if you want something to change it create an if/else statement in loop
Also white = sync, orange = antisync, blue = back of tank
other times vortech is solid white in feed at 0%. Night mode is breathing white @ 50% of internal memory speed
StuGotz
Post by StuGotz »
Yup, cleared the memory settings first. I have
ReefAngel.RF.UseMemory=false;
ReefAngel.RF.SetMode(Smart_NTM,120,6);
defined in my setup(). The Vortech went white like it paired fine, the module just kept flashing blue and green, instead of going solid green.
Deckoz2302
In setup - don't use
because you are declaring the internal memory value
also - if your trying to do nutrient transport module will turn purple
green = constant speed
StuGotz
Post by StuGotz »
Same issue so I reset the vortech again, uploaded the VortechSetup.PDE again, after I hit the joystick to finalize the settings, the vortech turns white, but the RF Module continues to blink blue and green instead of going to a solid green
Only thing in Setup is ReefAngel.RF.SetMode(Smart_NTM,120,6);
I've commented out everything else I had in my loop and custom menu. Here's a copy if anyone is interested.
// Autogenerated file by RAGen (v1.0.4.92), (10/15/2011 12:40)
// RA_101511_1240.pde
// MANY THANKS TO BOTH ROBERTO AND CURT FOR ALL THEIR HELP!*
#define wifi
#define VersionMenu
#define CUSTOM_MAIN
#define COLORS_PDE
#define CUSTOM_MENU
#define CUSTOM_MENU_ENTRIES 6
#define RFEXPANSION
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
#include <ReefAngel_Colors.h>
#include <avr/pgmspace.h>
#include <ReefAngel_RF.h>
#define Sump                1
#define DosingPump2         2
#define Refugium            3
#define Daylight            4
#define Actinic             5
#define Skimmer             6
#define Heater              7
#define DosingPump1         8
//Cloud & Lightning effects
byte ActinicPWMValue=0;
byte DaylightPWMValue=0;
boolean ForceCloud=false;
// Create the menu entries
prog_char menu3_label[] PROGMEM = "Force Cloud";
prog_char menu4_label[] PROGMEM = "Force Storm";
prog_char menu5_label[] PROGMEM = "Overheat Clear";
prog_char menu6_label[] PROGMEM = "PH Calibration";
prog_char menu7_label[] PROGMEM = "Version";
menu4_label, menu5_label, menu6_label, menu7_label
// Menu Item actions
void MenuEntry1()
ReefAngel.FeedingModeStart();
void MenuEntry2()
void MenuEntry3()
ForceCloud=true;
void MenuEntry4()
ForceCloud=true;
//ReefAngel.RF.UseMemory=false; // Sets variable so default memory modes for RF Module are not used
//ReefAngel.RF.SetMode(10,150,0); // Sets Storm mode (10) on Vortech pumps at 150/255 speed, and 0 duration since not applicable to this mode.
void MenuEntry5()
ReefAngel.OverheatClear();
void MenuEntry6()
ReefAngel.SetupCalibratePH();
void MenuEntry7()
ReefAngel.DisplayVersion();
// Custom Main Screen
  ReefAngel.LCD.DrawText(COLOR_WHITE, COLOR_CORNFLOWERBLUE, 0, 0, "                       "); //Top Banner
  ReefAngel.LCD.DrawText(COLOR_WHITE, COLOR_CORNFLOWERBLUE, 0, 2, " BioCube 14 Nano Reef  "); //Top Banner
  ReefAngel.LCD.DrawDate(6, 123);
  // Display Temp Text
  ReefAngel.LCD.DrawText(0,255,12,12,"Temp");
  // Display the T1 temp value 10,22
  char text[7];
  ReefAngel.LCD.Clear(255, 0, 22, 50, 36);
  ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE, 255, 10, 22, text, Num8x16);
  // Display pH Text
  ReefAngel.LCD.DrawText(0,255,100,12,"pH");
  // Display pH Value
  ReefAngel.LCD.Clear(255, 90, 22, 98, 36);
  ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE, 255, 90, 22, text, Num8x16);
  // Display Actinic Percentage Text
  ReefAngel.LCD.DrawText(0,255,8,40,"Actinic %");
  // Display the Actinic PWM channel value at 90,40
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetActinicValue(),COLOR_CORNFLOWERBLUE, 90, 40, 1);
  // Display Daylight Percentage Text
  ReefAngel.LCD.DrawText(0,255,8,50,"Daylight %");
  // Display the Daylight PWM channel value at 90,50
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetDaylightValue(),COLOR_CORNFLOWERBLUE, 90, 50, 1);
  // Display T2 Temp Text
  ReefAngel.LCD.DrawText(0,255,8,60,"Canopy Temp");
  // Display the T2 temperature value at 90,60
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp2, COLOR_CORNFLOWERBLUE, 90, 60, 10);
  // Display T3 Temp Text
  ReefAngel.LCD.DrawText(0,255,8,70,"Ambient Temp");
  // Display the T3 temperature at 90,70
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp3, COLOR_CORNFLOWERBLUE, 90, 70, 10);
  // Display Vortech MP10ew Mode Text at 90, 80
  ReefAngel.LCD.DrawText(0,255,8,80,"EcoSmart Mode");
  // Display EcoSmart Mode Value
  //ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,90,80,"Storm");
  //ConvertNumToString(text, InternalMemory.RFMode_read(), 1);
  //ReefAngel.LCD.Clear(255, 90, 80, 98, 90);
  ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE, 255, 90, 80, InternalMemory.RFMode_read());
  //pingSerial();
  ReefAngel.LCD.DrawOutletBox(13, 97, TempRelay);
 // ReefAngel.LCD.DrawGraph(5,7);
  ReefAngel.InitMenu(pgm_read_word(&(menu_items[0])),SIZE(menu_items)); //For Custom Menu
  ReefAngel.FeedingModePorts = B00100001; //Ports 6 & 1 turn off
  ReefAngel.WaterChangePorts = B00100001; //Ports 6 & 1 turn off
  ReefAngel.OverheatShutoffPorts = B00011000; //Ports 4 & 5 turn off
  ReefAngel.LightsOnPorts = B00011000; //Ports 4 & 5 turn on
 // ReefAngel.RF.UseMemory=false;
  ReefAngel.Relay.On(Port1);
  // Delay Skimmer port 5 minutes whenever turned on
  // From Curt - THANKS CURT!
  ReefAngel.Relay.DelayedOn(Port6, 5);
  //Heater
  ReefAngel.StandardHeater(Heater,775,780);  // Setup Heater to turn on at 77.5F and off at 78.0F
  //Lighting schedule
  ReefAngel.MHLights(Daylight,9,0,17,0,0);  //Daylight schedule 9:00am - 5:00pm with 0min cool down
  ReefAngel.StandardLights(Actinic,7,0,19,0);  //Actinic schedule 7:00am - 7:00pm
  ReefAngel.StandardLights(Refugium,19,0,7,0);  //Refugium schedule 7:00pm - 7:00am
  // Dosing pumps (OLD DOSING METHOD OF PUMP ONE ON THE HOUR, THEN PUMP2 5 MIN LATER - to use when tank is more mature
  //From Roberto - THANKS ROBERTO!
   /* if (ReefAngel.DisplayedMenu==255 && minute()==0 && second()<1)  //Alk Doser - Only works if Main screen is showing
      ReefAngel.Relay.On(DosingPump1);  //Turn Alk Doser on
      ReefAngel.Relay.Off(DosingPump1);  //Turn Alk Doser off
    if (ReefAngel.DisplayedMenu==255 && minute()==5 && second()<1)  //CA Doser - Only works if Main screen is showing
      ReefAngel.Relay.On(DosingPump2);  //Turn CA Doser on
      ReefAngel.Relay.Off(DosingPump2);  //Turn CA Doser off
  // Dosing pumps
  // From Roberto - THANKS ROBERTO!
  if (ReefAngel.DisplayedMenu==255 && hour()%2==0 && minute()==0 && second()<1) // 1 sec dosing on even hours
    ReefAngel.Relay.On(DosingPump1);  //Turn DosingPump1 Doser on
    ReefAngel.Relay.Off(DosingPump1);  //Turn DosingPump1 Doser off
  if (ReefAngel.DisplayedMenu==255 && hour()%2==1 && minute()==0 && second()<1) // 1 sec dosing on odd hours
    ReefAngel.Relay.On(DosingPump2);  //Turn DosingPump2 Doser on
    ReefAngel.Relay.Off(DosingPump2);  //Turn DosingPump2 Doser off
  // Cloud & Lightning effects - Calculate your regular sunrise/sunset PWM value
  // byte PWMSlope(byte startHour, byte startMinute, byte endHour, byte endMinute, byte startPWM, byte endPWM, byte Duration, byte oldValue)
  if (hour()>=19 || hour()<7)
      ReefAngel.PWM.SetActinic(MoonPhase());  //Moon phase schedule between 7:00pm - 7:00am
      //ReefAngel.RF.SetMode(Smart_NTM,10,5); // Sets Night mode on Vortech pumps
      ActinicPWMValue=PWMSlope(7,00,19,0,0,35,60,ActinicPWMValue); //Actinic turn on at 7am, off at 10am, and ramp up 0% to 50% PWM in 60 minutes
      //ActinicPWMValue=PWMSlope(16,00,19,0,0,50,60,ActinicPWMValue); //Actinic turn on at 4pm, off at 7pm, and ramp up 0% to 50% PWM in 60 minutes
      //ReefAngel.RF.SetMode(Smart_NTM,106,10); // Sets Day mode on Vortech pumps
  DaylightPWMValue=PWMSlope(9,00,17,0,0,75,60,DaylightPWMValue); //Daylight turn on at 9am, off at 5pm, and ramp up 0% to 50% PWM in 60 minutes
  CheckCloud();
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 15
#define Min_Clouds_per_Day 3
#define Max_Clouds_per_Day 6
  // In this example, end could before 4:30pm
#define End_Cloud_Before NumMins(16,30)
#define Lightning_Change_per_Cloud 25
  // Which could mean 250 minutes of clouds. We need to make sure the PWMSlope can accomodate 250 minutes of effects or unforseen result could happen.
  static byte cloudchance=255;
  static byte cloudduration=0;
  static int cloudstart=0;
  static byte numclouds=0;
  static byte cloudindex=0;
  static int LastNumMins=0;
#ifdef forcecloudcalculation
  if (cloudchance==255)
#else
#endif
      cloudchance=random(100);
      // If we have cloud today
      if (cloudchance)
        lightningchance=random(100);
  //When custom menu Force cloud is selected
  if (ForceCloud)
    ForceCloud=false;
    cloudchance=1;
    cloudduration=10;
    lightningchance=1;
    cloudstart=NumMins(hour(),minute())+1;
  if (cloudchance)
    //is it time for cloud yet?
        else lightningstatus=0;
        if (lightningstatus)
          DaylightPWMValue=100;
          ActinicPWMValue=100;
          DaylightPWMValue=0;
          ActinicPWMValue=0;
        delay(1);
      cloudindex++;
      if (cloudindex < numclouds)
    ReefAngel.LCD.Clear(255,0,113,132,121);
    ReefAngel.LCD.DrawText(0,255,12,113,"C");
    ReefAngel.LCD.DrawText(0,255,18,113,"00:00");
    ReefAngel.LCD.DrawText(0,255,52,113,"L");
    ReefAngel.LCD.DrawText(0,255,58,113,"00:00");
    ReefAngel.LCD.DrawText(0,255,93,113,"DUR");
      int x=0;
      if ((cloudstart/60)>=10) x=18;
      else x=24;
      ReefAngel.LCD.DrawText(0,255,x,113,(cloudstart/60));
      if ((cloudstart%60)>=10) x=36;
      else x=42;
      ReefAngel.LCD.DrawText(0,255,x,113,(cloudstart%60));
    ReefAngel.LCD.DrawText(0,255,114,113,cloudduration);
    if (lightningchance)
      int x=0;
      if (((cloudstart+(cloudduration/2))/60)>=10) x=88;
      else x=94;
      ReefAngel.LCD.DrawText(0,255,x,113,((cloudstart+(cloudduration/2))/60));
      if (((cloudstart+(cloudduration/2))%60)>=10) x=109;
      else x=112;
      ReefAngel.LCD.DrawText(0,255,x,113,((cloudstart+(cloudduration/2))%60));
  cstart*=60;
  cend*=60;
  if (n>cend) return PWMStart;
  //End Cloud & Lighting
Deckoz2302
I feel as though you need to declare something in your loop somewhere - perfect placeis in your moonphase if statement.... try adding lines similar to this and see if it changes anything >.<
if ( hour() <= 6 || hour () >= 19 ) // Moonlights on from 7PM to 7AM
ReefAngel.PWM.SetActinic(0);
ReefAngel.RF.UseMemory=true;
StuGotz
Post by StuGotz »
No change. Does your RF Module constantly blink blue and green? The manual says it should go solid green after a successful sync, so I'm wondering if it's even sending RF commands to the Vortech.
StuGotz
Post by StuGotz »
OK unplugged everything, let is sit for about 30 secs and plugged it all back in. Now the vortech is breathing white, so must be in night mode. The RF Module is breathing white too. <shrug> works for me!
I'll double check, but I think after you described what you experienced, I may have forgotten something on the vortechsetup.pde file.
I have always used a controller with internal memory already initialized, so that's why it would turn green (constant mode), because it was what I had already set on my internal memory.
I think what happened in here was that your internal memory has an unknown value.
I can't remember if you have wifi. If you do, would you please browse to http://youripaddress:2000/mb855 and let me know what you see on the browser?
Deckoz2302
I used the first vortechsetup.pde that rimai posted and just declared random2,155,0 in setup. other then that i have the code posted above and a code to set vortech in ntm for 30 min after feed mode and all worked fine....if its breathing white its in night mode...wait til morning see what it does.
StuGotz
Post by StuGotz »
Sorry no wifi, I connect via USB. I didn't set an internal memory value manually, I just added ReefAngel.RF.SetMode(Smart_NTM,120,6); to my setup() like Deckoz2302 suggested. I looked in the Reef Angel Client a couple days ago to see if I could set it in there before I got the module, but didn't see anywhere I could set the internal memory settings outside of what's in the Memory tab.
StuGotz
Post by StuGotz »
Deckoz2302 wrote:I used the first vortechsetup.pde that rimai posted and just declared random2,155,0 in setup. other then that i have the code posted above and a code to set vortech in ntm for 30 min after feed mode and all worked fine....if its breathing white its in night mode...wait til morning see what it does.
I think it's all good now. I'll be feeding my Poseidon complex during my lunch break tomorrow for sure :) Thanks for the help!
Ok, so here is what I'd like you to do.
Shut the Client Listener service if you have it running.
On Arduino IDE, open Serial Monitor and make sure it is set to 57600 baud.
Type: GET /mb855
After you type this, make sure you hit at least one time the space in your keyboard, then hit enter.
It should give you something on the screen.
Paste it her, please :)
StuGotz
Post by StuGotz »
It says:
HTTP/1.1 200 OK
Server: ReefAngel
Pragma: no-cache
Connection: close
Content-Type: text/xml
Content-Length: 118
<M855>255</M855>
Which is the same thing InternalMemory.RFMode_read() is returning. I was going to bug you later about if it should return a number or a string, like Storm, Night, etc
Just as I was thinking.
I'll change the setup code to initialize the memory.
Thank you so much for finding the bug.
Now, to fix your memory, you can simply type: GET /mb855,0
Same thing. Make sure you get space before hitting enter.
This will place 0 on the internal memory, which is constant. If you want to use a different value, just use the equivalent number of the mode you wish to be the default mode.
Oh, make sure to place values on 856 and 857 too.
855- mode
856- speed
857- duration
StuGotz
Post by StuGotz »
All 3 internal memory areas set. Thanks again.
Deckoz2302
Hmmm, I noticed the same thing as stu except my mode value is 4 whether or not the other modes are switched due to if statements. I believe each time we reference the mode value in our code we could write something like this in our custom main
If (InternalMemory.RFmode_read() == 4) ReefAngel.LCD.DrawText(COLOR_YELLOW,DefaultBGColor,8,y+13,"Reef Crest:");
Else (InternalMemory.RFmode_read() == 8)ReefAngel.LCD.DrawText(COLOR_VIOLET,DefaultBGColor,8,y+13,"Nutrient Transport");// not sure of actual numbers for each mode gotta look at global.h
But the problem is when we say use memory false in our code the setmode doesn't rewrite internal memory value so it probably won't work. if we made a global value though. Like byte vtechmode; above setup and then in our if statement for moonphase or feeding or what have you. Add this line
if ( hour() <= 6 || hour () >= 20 )
ReefAngel.RF.SetMode(Night,10,0);
vtechmode = 11//not sure of night number
else { ReefAngel.PWM.SetActinic(0);
Vtechmode = InternalMemory.RFmode_read();
If (vtechmode == 11) reefangel draw text ect ect we would have to have this if statement in custom main otherwise if it is in loop it will show up on every screen - which is why we should create a global byte and set change the value in loop() and intialize its value in setup() with vtechmode = internalmem.....
Then in our custom write it like
Deckoz2302
When I get home today rimai I may add to your vortechsetup pde and upload it for you, so that once slaves are set menu pops up to select default mode, speed % and pulse duration.
Gotta look at the code to figure out how you do a scroll select like tempuratures on the preloaded pde(like how you select water/lights/room)
Mode would have to be simple string array? And use the number of the position to set value
Speed would be internalmemory rfspeed write = abs((percent * 0.01) * 255)
Duration would just be 0-255 selection
