2nd Relay with no power
Rodasphoto
Re: 2nd Relay with no power
Post by Rodasphoto »
rimai wrote:It will increase the watchdog. I'm thinking you are having some of the problems that others have had and this code fixed it.
The watchdog patch is in the next release of libraries.
You can place the code in the setup() section, right after ReefAngel.Init();
Just make sure it is after and not before.
Should it look like this?
    wdt_enable(WDTO_8S);
    ReefAngel.FeedingModePorts = Port1Bit | Port4Bit | Port6Bit | Port8Bit;
    ReefAngel.FeedingModePortsE[0] = Port3Bit | Port4Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
    ReefAngel.WaterChangePortsE[0] = Port4Bit;
    ReefAngel.LightsOnPorts = Port2Bit;
    ReefAngel.LightsOnPortsE[0] = Port1Bit;
    ReefAngel.OverheatShutoffPorts = Port1Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
    ReefAngel.OverheatShutoffPortsE[0] = Port3Bit;
    InternalMemory.OverheatTemp_write( 840 );
    ReefAngel.StandardLights( Port2,9,0,21,10 );
    ReefAngel.StandardLights( Port3,9,0,21,30 );
    ReefAngel.StandardLights( Port4,9,0,21,30 );
    ReefAngel.WavemakerRandom1( Port5,30,100 );
    ReefAngel.WavemakerRandom2( Port6,30,100 );
    ReefAngel.StandardHeater( Port7,778,784 );
    ReefAngel.StandardLights( Box1_Port1,9,0,21,40 );
    ReefAngel.StandardLights( Box1_Port4,9,0,21,0 );
    ReefAngel.PWM.SetChannel( 0, PWMParabola(9,0,21,0,0,100,0) );
    ReefAngel.PWM.SetChannel( 1, PWMParabola(9,0,21,0,0,100,0) );
    ReefAngel.PWM.SetChannel( 2, PWMParabola(9,0,21,0,0,100,2) );
    ReefAngel.PWM.SetChannel( 3, PWMParabola(9,0,21,0,0,75,0) );
    ReefAngel.PWM.SetChannel( 4, PWMParabola(9,0,21,0,0,75,0) );
    ReefAngel.PWM.SetChannel( 5, PWMParabola(9,0,21,0,0,60,3) );
    if (hour()<9 || hour()>=21)
    ReefAngel.Relay.Off(Port5);
    ReefAngel.Relay.Off(Port6);
    ReefAngel.Portal( "Rodasphoto" );
    int x,y;
    // Dimming Expansion
    x = 15;
    y = 2;
    for ( int a=0;a<6;a++ )
      if ( a>2 ) x = 75;
      if ( a==3 ) y = 2;
      y += 10;
    ReefAngel.LCD.DrawMonitor( 15, 39, ReefAngel.Params,
    ReefAngel.LCD.DrawMonitor( 15, 39, ReefAngel.Params );
    ReefAngel.LCD.DrawOutletBox( 12, 76, TempRelay );
    // Relay Expansion
    ReefAngel.LCD.DrawOutletBox( 12, 96, TempRelay );
Yeah :)
Rodasphoto
I cannot connect to my WiFi module. The green light blinks followed by the orange light. I tried resetting the RA by cycling the power. I am currently on 1.07. Should I update the libraries? You mentioned updating the firmware for the WiFi, how do I go about updating it?
Sent from my SCH-I535 using Tapatalk
Did you check if the router didn't assign the wifi attachment a new ip address?
Rodasphoto
The WiFi module shows up as a wireless client on my router (apple airport extreme). I can connect to the controller for a couple of hours and then a get a bad URL error message. Then the lights don't dim properly. If I try to reset the controller with my pwm module connected it wont reset. I have to disconnect my PWM module then disconnect the controller to reset it.
Do you want to try the new libs?
Rodasphoto
Yes. i really miss being able to control the RA from my phone.
Download the latest dev branch: https://github.com/reefangel/Libraries/archive/dev.zip
Unzup it.
Replace your folder \Documents\Arduino\libraries with the one you downloaded.
Upload your code again.
Rodasphoto
I just updated the libraries and uploaded the code again. Now the green light on the wifi module blinks and I am still unable to connect.
dbmet
Post by dbmet »
Have you run the wifi utility?
Rodasphoto
dbmet wrote:Have you run the wifi utility?
I ran it when I first received the Wi-Fi module.
Rodasphoto
Updated the firmware and reran the wifi utility. Everything seemed for OK. But when I woke up today the system was not responsive. I had to unplug my PWM module and power off the RA controller to get it to unfreeze then plugged my PWM module back in. I don't know what else to do.
Are you sure you updated the libraries with the dev branch?
Rodasphoto
I downloaded the files you asked me to took the old libraries out and placed the new ones in its place. I will retry it tomorrow and check back with my results.
Rodasphoto
I just reloaded the code with the new libraries. The arduino software states its version 1.0.9. Keeping my fingers crossed and hoping this time everything works as it should.
Rodasphoto
Reloaded the new library and eureka it works.
