RA ATO Pump
RA ATO Pump
Thinking of getting the RA ATO pump to replace my 50ml/min BRS ATO pump because I would like something that pumps a bit faster. What are the specs on the RA pump as in how many ml/min? Is it AC or DC? If it's AC is the pump AC or is it a DC pump with an AC/DC converter in the box and if so what DC voltage does the pump take? Does it take a special pump tube like the BRS ATO pump or can you use any standard silicone tubing to replace the internal pump tubing?
Re: RA ATO Pump
It uses 12VDC and it comes with the power supply.
It will pump about 200ml/min.
The tube is a pharmed tubing for longer ife and can be replaced by just changing the internal tubing when needed.
Re: RA ATO Pump
Perfect, thanks. I'll have to order one soon.
