The topic is basically the question.
Can the Dimmable Lunar Hub and Moonlights work off of the ATO low port?
I'm going to power it off the Power Control Expansion for the 12V it requires.
Dimmable Lunar Hub on ATO Low
Re: Dimmable Lunar Hub on ATO Low
Yes, the Lunar Hub works. The moonlights by itself will not.
OK. Thanks.
I had my moonlight go out last night and I still need to do some investigating (it may be the Power Control Expansion), but if it is the moonlights I was looking at a replacement.
Right now I really have no idea what it is, I noticed it this morning and didn't have time to looking into things that much before I had to leave for work, but the Power Control Expansion is showing a green light on it and I tried manually turning on my ATO and got nothing.
Heres whats im using .
pinMode(lowATOPin,OUTPUT);
if (InternalMemory.LEDPWMActinic_read()<=100)
analogWrite(lowATOPin,InternalMemory.LEDPWMActinic_read()*2.55);
analogWrite(lowATOPin,MoonPhase()*2.55);
Sent from my SAMSUNG-SGH-I337 using Tapatalk
