program dosing pumps
Posted: Wed Jan 01, 2014 4:23 am
by anderzon_
Can I program the dosing pump to pump one starts at 08:00 and pumps 5 sec, pump 2 at 09.00 and pumps 5 sec, pump 3 at 10:00 and pumps 5 sec in the morning? And then every three hours until 10 pm? They will not dose on the night. Want it to be so during the day if it's possible?
Re: program dosing pumps
Posted: Wed Jan 01, 2014 10:24 am
Yes, use the wizard and choose to pump every 180minutes (3 hours) for 5 seconds and then for pump 1, choose 0 minutes offset. For pump2, 60 minutes offset and pump3 120 minutes offset.
Posted: Thu Jan 02, 2014 3:38 pm
by anderzon_
Thank you. Are they turned off at night then?
Posted: Thu Jan 02, 2014 3:52 pm
Oh no... Sorry..
You can wrap the functions in an if statement to run them only during day.
if (hour() > 8 && hour() < 22)
// Place your code here
Posted: Thu Jan 09, 2014 10:19 am
by anderzon_
I dont get it. How should the complete code look like and where should I place it?
Posted: Thu Jan 09, 2014 10:40 am
if you look in your code, there is a section for custom code.
You should place right there.
Posted: Thu Mar 01, 2018 3:44 am
by anderzon_
Lift this old thread.
I cant remember how I get it done last time.
Is this correct? If I the doser should be off at night?
Is it ok to place it in the loop or should it be in custom?
if (hour() > 8 && hour() < 22) ReefAngel.DosingPumpRepeat( Box1_Port1,0,360,6 );
Thanks for all help
