Automatically rebooting Wifi
I was having problems with my router losing the connection to my Wifi module. I added a second router closer to my Wifi module. This has helped but I still lose the connection to the Wifi module. To fix the issue I disconnect the Wifi module and plug it back in to the RA. I was wondering if there was one wire that could be switched that would recreate this behaviour or does it require more than one wire to be unplugged? I could wire up a timer that disconnects the wire everyday at 11:00 AM and reconnects it a minute later. I could not do it in the middle of the night because when I unplug my Wifi module it turns my LEDs to 100%. I am not sure if I am resetting my Wifi module or RA or both when I unplug the Wifi module.
Re: Automatically rebooting Wifi
Have you tried updating the firmware?
You will need teraterm, putty or any other serial terminal to do that.
Looks like it is 4.40:
https://www.microchip.com/pagehandler/e ... tml?tab=t2
