Wifi Utility said my address was : 192.168.0.13
So based on his screen shot is that now static??
This is getting old fast!
Unreachable Address
Re: Unreachable Address
- Screen Shot 2014-01-20 at 9.31.56 AM.png (446.61 KiB) Viewed 3056 times
Kevin
or am I supposed to do something here?
- Screen Shot 2014-01-20 at 9.36.10 AM.png (388.9 KiB) Viewed 3056 times
Kevin
The first one looks good. The second is for your cable connection leave that one alone.
Everything was live for 5 minutes.
Now Green Light is steady, Yellow light is blinking and I see this on the portal:
- Screen Shot 2014-01-20 at 10.30.17 AM.png (334.13 KiB) Viewed 3054 times
Kevin
Are you able to connect to your module using the internal ip address and the phone app?
Meaning xxx.xxx.x.x:2000?rimai wrote:Are you able to connect to your module using the internal ip address and the phone app?
Kevin
yes...
use ip address 192.168.0.13 and port 2000
Also, what happens when you browse that ip address?
http://192.168.0.13:2000
They both work.... after I reboot... But only thenrimai wrote:yes...
Kevin
