I have been having issues with my salinity probe readings. I initially calibrated with 35ppt solution used for refractometers. The value from the calibration screen was ~30ppt. Then I placed the probe in my tank and it read 20ppt and it has been decreasing steadily. I have cross checked salinity with 2 separate refractometers, one of them temperature compensating, and I have 36ppt. Heck, I even used the floating needle type and it was in the 36 neighborhood.
Thinking it was maybe temperature related I tuned on the temperature compensation function and re-calibrated, but same results. Anyone have any idea about this or has run into the same issue?
Any help is gladly appreciated!
P.S.: My first post, so please be gentle...
Hugo
Issue with Salinity Expansion/Probe
Re: Issue with Salinity Expansion/Probe
Can you place it in a cup of tank water, calibrate and leave it there for a few days?
OK, I was scanning on the forums and ran into someone that said micro-bubbles may affect salinity readings, so I moved to the pump side of the sump, away from the skimmer and it is holding at 30 ppt, however, my salinity is 35ppt, not 30. Anything else I should be checking?
Try recalibrating with the probe in the tank.
Your solution may not be good for electronic meters.
Remember that we are measuring conductivity and not light refraction.
