Relay exp without dip switch
anderzon_
Post by anderzon_ »
I opened the box according to the manual but there are no dip switches and the relay box can not get started?
Re: Relay exp without dip switch
Can you post a photo?
anderzon_
Post by anderzon_ »
It´s up and running right now.
I do not know if it is working properly yet. Have just set all ports on. The error I did before was that I had all of. I changed to always on so I got it to work. But as I said, there was no switch to change.
You are opening the wrong thing.
The dip switches are in the expansion module and not in the relay box.
There is nothing to be changed in the relay box and didn't need to be opened.
anderzon_
Post by anderzon_ »
Do I need to change the switches and how should it be?
The switch selection is in the manual.
