jebao wp25 cuts out
jebao wp25 cuts out
My jebao runs for several hours then shuts off then I have to physicaly unplug it and replug it in to make it come back on I have it on my daylight channel and I have a pwm controller it is in reef crest mode (2) using internal memory that s happens regardless of the dcpump speed setting
Re: jebao wp25 cuts out
I have noticed that the Jebao pumps have a minimum percentage that they can not go below.
For example if my WP-40 goes below 25% it will stop and then I have to unplug it, while if my WP-25 goes below 30% the same thing will happen.
So I just set my code that is never goes below 30%.
If you are using on of the preset modes, like Lagoon and it has a percentage followed by a range mine is set for 50, 20 so that the mid point would be 50% and it would range 20% around that, therefore it never gets below 30%.
