rimai wrote:Can you paste the log of the factory reset?
Opening Serial Port...
Verifying speed at 9600 baud
Connected to serial port COM4
< CMD
> set u b 57600
< set u b 57600
< AOK
< <4.41>
> set s p 0
> save
> reboot
Verifying speed at 57600 baud
Removing connection to COM4
< CMD
> reboot
< reboot
Wifi Attachment Connected to COM4
< CMD
> ls
< ls
< FL# SIZ FLAGS
< 2 86328 3 wifly-GSX-400
< 4 74920 3 web_app-GSX-106
< 7 46632 3 wps_app-GSX-131
< 9 66240 3 eap_app-GSX-101
< 11 37282 0 web_config.html
< 21 512 0 link.html
< 24 1052 10 config
< 25 944 10 user
< 26 88548 3 wifly-GSX-441-r1057
< 145 Free, Boot=26, Backup=2
< <4.41>
> load user
< load user
< AOK
< <4.41>
> save
< save
< Storing in config
< *BAD CONFIG*
< <4.41>
> save
< save
< Storing in config
< *BAD CONFIG*
< <4.41>
> set o d ReefAngelWifi
< set o d ReefAngelWifi
< AOK
< <4.41>
> set w l 5
< set w l 5
< AOK
< <4.41>
> set w s Dhouse
< set w s Dhouse
< AOK
< <4.41>
> set w p 5198545981
< set w p 5198545981
< AOK
< <4.41>
< AOK
< <4.41>
< AOK
< <4.41>
> save
< save
< Storing in config
< *BAD CONFIG*
< <4.41>
> reboot
< reboot
< CMD
> set u b 57600
< set u b 57600
< AOK
< <4.41>
> set s p 0
> save
< <4.41>
> reboot
< CMD
> reboot
< reboot
< CMD
> ls
< ls
< FL# SIZ FLAGS
< 24 1052 10 config
< 25 944 10 user
< <4.41>
> load user
< load user
< AOK
< <4.41>
> save
< save
< Storing in config
< *BAD CONFIG*
< <4.41>
> save
< save
< Storing in config
< *BAD CONFIG*
< <4.41>
< AOK
< <4.41>
> set w l 5
< set w l 5
< AOK
< <4.41>
> set w s Dhouse
< set w s Dhouse
< AOK
< <4.41>
> set w p 5198545981
< AOK
< <4.41>
< AOK
< <4.41>
< AOK
< <4.41>
> save
< save
< Storing in config
< *BAD CONFIG*
< <4.41>
> reboot
< reboot
> set u b 57600
> set s p 0
> save
> reboot
< CMD
> reboot
< reboot
< CMD
> factory RESET
< factory RESET
< Set Factory Defaults
> reboot
< <4.41>
< reboot
Factory Settings Restored
> set u b 57600
> set s p 0
> save
> reboot
< CMD
> reboot
< reboot
< CMD
> ls
< ls
< FL# SIZ FLAGS
< 24 1052 10 config
< 25 944 10 user
< <4.41>
> load user
< load user
< AOK
< <4.41>
> save
< save
< Storing in config
< *BAD CONFIG*
< <4.41>
> save
< save
< Storing in config
< *BAD CONFIG*
< <4.41>
< AOK
< <4.41>
> set w l 5
< set w l 5
< AOK
< <4.41>
> set w s Dhouse
< set w s Dhouse
< AOK
< <4.41>
> set w p 5198545981
< AOK
< <4.41>
< AOK
< <4.41>
< AOK
< <4.41>
> save
< save
< Storing in config
< *BAD CONFIG*
< <4.41>
> reboot
< reboot
< CMD
> set u b 57600
< set u b 57600
< AOK
< <4.41>
> set s p 0
> save
> reboot
< CMD
> reboot
< reboot
< CMD
> factory RESET
< factory RESET
> reboot
< <4.41>
< reboot
> set u b 57600
> set s p 0
> save
> reboot
< CMD
> reboot
< reboot
< CMD
> ls
< ls
< FL# SIZ FLAGS
< 24 1052 10 config
< 25 944 10 user
< <4.41>
> load user
< load user
< AOK
< <4.41>
> save
< save
< Storing in config
< *BAD CONFIG*
< <4.41>
> save
< save
< Storing in config
< *BAD CONFIG*
< <4.41>
< AOK
< <4.41>
> set w l 5
< set w l 5
< AOK
< <4.41>
> set w s Dhouse
< set w s Dhouse
< AOK
< <4.41>
> set w p 5198545981
< AOK
< <4.41>
< AOK
< <4.41>
< AOK
< <4.41>
> save
< save
< Storing in config
< *BAD CONFIG*
< <4.41>
> reboot
< reboot
< CMD
> set u b 57600
< set u b 57600
< AOK
< <4.41>
> set s p 0
> save
> reboot
< CMD
> reboot
< reboot
< CMD
> ls
< ls
< FL# SIZ FLAGS
< 24 1052 10 config
< 25 944 10 user
< <4.41>
> load user
< load user
< AOK
< <4.41>
> save
< save
< Storing in config
< *BAD CONFIG*
< <4.41>
> save
< save
< Storing in config
< *BAD CONFIG*
< <4.41>
< AOK
< <4.41>
> set w l 5
< set w l 5
< AOK
< <4.41>
> set w s Dhouse
< set w s Dhouse
< AOK
< <4.41>
> set w p 5198545981
< AOK
< <4.41>
< AOK
< <4.41>
< AOK
< <4.41>
> save
< save
< Storing in config
< *BAD CONFIG*
< <4.41>
> reboot
< reboot
< CMD
> set u b 57600
< set u b 57600
< AOK
< <4.41>
> set s p 0
> save
> reboot
< CMD
> reboot
< reboot
< CMD
> ls
< ls
< FL# SIZ FLAGS
< 24 1052 10 config
< 25 944 10 user
< <4.41>
> load user
< load user
< AOK
< <4.41>
> save
< save
< Storing in config
< *BAD CONFIG*
< <4.41>
> save
< save
< Storing in config
< *BAD CONFIG*
< <4.41>
< AOK
< <4.41>
> set w l 5
< set w l 5
< AOK
< <4.41>
> set w s Dhouse
< set w s Dhouse
< AOK
< <4.41>
> set w p 5198545981
< AOK
< <4.41>
< AOK
< <4.41>
< AOK
< <4.41>
> save
< save
< Storing in config
< *BAD CONFIG*
< <4.41>
> reboot
< reboot
< CMD
> set u b 57600
< set u b 57600
< AOK
< <4.41>
> set s p 0
> save
> reboot
< CMD
> reboot
< reboot
< CMD
> factory RESET
< factory RESET
> reboot
< <4.41>
< reboot
> set u b 57600
> set s p 0
> save
> reboot
< CMD
> reboot
< reboot
< CMD
> ls
< ls
< FL# SIZ FLAGS
< 24 1052 10 config
< 25 944 10 user
< <4.41>
> load user
< load user
< AOK
< <4.41>
> save
< save
< Storing in config
< *BAD CONFIG*
< <4.41>
> save
< save
< Storing in config
< *BAD CONFIG*
< <4.41>
< AOK
< <4.41>
> set w l 5
< set w l 5
< AOK
< <4.41>
> set w s Dhouse
< set w s Dhouse
< AOK
< <4.41>
> set w p 5198545981
< AOK
< <4.41>
< AOK
< <4.41>
< AOK
< <4.41>
> save
< save
< Storing in config
< *BAD CONFIG*
< <4.41>
> reboot
< reboot
< CMD
> set u b 57600
< set u b 57600
< AOK
< <4.41>
> set s p 0
> save
< <4.41>
> reboot
< CMD
> reboot
< reboot
< CMD
> factory RESET
< factory RESET
> reboot
< <4.41>
< reboot
> set u b 57600
> set s p 0
> save
> reboot
< CMD
> reboot
< reboot
< CMD
> set u b 57600
< set u b 57600
< AOK
< <4.41>
> set s p 0
> save
> reboot
< CMD
> reboot
< reboot
< CMD
> ls
< ls
< FL# SIZ FLAGS
< 24 1052 10 config
< 25 944 10 user
< <4.41>
> load user
< load user
< AOK
< <4.41>
> save
< save
< Storing in config
< *BAD CONFIG*
< <4.41>
> save
< save
< Storing in config
< *BAD CONFIG*
< <4.41>
< AOK
< <4.41>
> set w l 5
< set w l 5
< AOK
< <4.41>
> set w s Dhouse
< set w s Dhouse
< AOK
< <4.41>
> set w p 5198545981
< AOK
< <4.41>
< AOK
< <4.41>
< AOK
< <4.41>
> save
< save
< Storing in config
< *BAD CONFIG*
< <4.41>
> reboot
< reboot
< CMD
> set u b 57600
< set u b 57600
< AOK
< <4.41>
> set s p 0
> save
> reboot
< CMD
> reboot
< reboot
< CMD
> factory RESET
< factory RESET
> reboot
< <4.41>
< reboot
> set u b 57600
> set s p 0
> save
> reboot
< CMD
> reboot
< reboot
< CMD
> factory RESET
< factory RESET
> reboot
< <4.41>
< reboot
