Salinity Quit On Me...
keithb
Post by keithb »
...While I was working on the tank this evening, so I probably did something. I tried reseating everything to no avail. How can I tell if it's the probe or the module that's giving me trouble?
Re: Salinity Quit On Me...
Can you check is the power supply is working?
Does it have the green led on the side lit?
keithb
Post by keithb »
LED on both the wall wart and the Module are on. Tried reseating both the probe cable and the USB cable as well as trying different ports in the expansion hub.
Run the I2CScanner code and post the results:
http://forum.reefangel.com/viewtopic.php?p=18831#p18831
keithb
Post by keithb »
I2CScanner ready!
addr: 1 addr: 2 addr: 3 addr: 4
addr: 5 addr: 6 addr: 7 addr: 8
addr: 9 addr: A addr: B addr: C
addr: D addr: E addr: F addr: 10
addr: 11 addr: 12 addr: 13 addr: 14
addr: 15 addr: 16 addr: 17 addr: 18
addr: 19 addr: 1A addr: 1B addr: 1C
addr: 1D addr: 1E addr: 1F addr: 20 found!
addr: 21 addr: 22 addr: 23 addr: 24
addr: 25 addr: 26 addr: 27 addr: 28
addr: 29 addr: 2A addr: 2B addr: 2C
addr: 2D addr: 2E addr: 2F addr: 30
addr: 31 addr: 32 addr: 33 addr: 34
addr: 35 addr: 36 addr: 37 addr: 38 found!
addr: 39 addr: 3A addr: 3B addr: 3C
addr: 3D addr: 3E addr: 3F addr: 40
addr: 41 addr: 42 addr: 43 addr: 44
addr: 45 addr: 46 addr: 47 addr: 48
addr: 49 addr: 4A addr: 4B addr: 4C
addr: 4D found! addr: 4E addr: 4F addr: 50 found!
addr: 51 addr: 52 addr: 53 addr: 54 found!
addr: 55 addr: 56 addr: 57 addr: 58
addr: 59 addr: 5A addr: 5B addr: 5C
addr: 5D addr: 5E addr: 5F addr: 60
addr: 61 addr: 62 addr: 63 addr: 64
addr: 65 addr: 66 addr: 67 addr: 68 found!
addr: 69 addr: 6A addr: 6B addr: 6C
addr: 6D addr: 6E addr: 6F addr: 70
addr: 71 addr: 72 addr: 73 addr: 74
addr: 75 addr: 76 addr: 77 addr: 78
addr: 79 addr: 7A addr: 7B addr: 7C
addr: 7D addr: 7E addr: 7F addr: 80
done
addr: 4D found! means the controller is seeing the module.
Can you double check your probe?
If you do into calibration, does is show any numbers?
keithb
Post by keithb »
It shows a 0 and I've reseated it multiple times.
Try cleaning it. Maybe it got calcium deposit? If that doesn't work, you will need to send it back to be analysed. Pm me for a RMA number.
Sent from my Galaxy S3 using Tapatalk
