Wow, that's cool, that means if there's a really bad power cut, I could connect the leads directly to my car battery in the garage and use it as a "generator"
Would this work as a "charger" instead of the solar panel? : http://www.vacuumspot.com.au/electrolux ... vQodi5MAuQ
Jebao Battery Backup
Re: Jebao Battery Backup
Hahaha... Yeap, you got the idea
Expensive generator... lol
That charger doesn't specify the battery that it can charge. Make sure the charger is made for the type of battery you are using, but I think it may work.
Thanks Roberto, your support is great in this forum!
I just want to make sure I'm understanding this right...
Out of the box,The battery does not get charged unless by the solar charger?
It's not constantly trickle charged via mains power? (no 110v plug?)
Correct. Only solar.
If you want a trickle charger, you would need to get your own, but you can definitely plug it in instead of the solar.
Would it be much to swap out the battery for a LithiumIon bank or would the solar charger not be compatible?
You would have to get the bank and a lipo chrager, but it would too.
