DC3000 and Jebao cable not working
MisterTang
Post by MisterTang »
So I just got my Jebao cable this evening, and I connected it all up only to have it not run :cry:
Verified there is power, because it appears to be slightly moving water, but barely at all.
This is my code:
    if (hour() > 7 && hour() < 20 )
      ReefAngel.DCPump.SetMode( ReefCrest,75,20 );
      ReefAngel.DCPump.SetMode( ReefCrest,40,10 );
Now, the RA unit itself shows that it should be working - it added some menu that says "Reef Crest" on it, and in addition, it shows the Daylight dimming channel being within my range. The DC3000 is definitely getting power, because it's pushing a slight amount of water.
Any suggestions would be most appreciated.
EDIT: Forgot to mention that I tried both of my PWM ports.
Re: DC3000 and Jebao cable not working
Your trying to run a pump like a powerhead. I dont think these have the responsiveness to run waveforms like the wp pumps.
Try setting them to a constant % and make sure its responding with the speeds you expect. Then we'll go from there...
What happens if you use it in constant 100%, does it run at 100%?
MisterTang
Okay, so here's my new code:
    ReefAngel.DCPump.SetMode( Constant,95,10 );
I am getting the same results as before. The pump is definitely powered on because there is extremely slight water movement.
Do you have a meter to test the voltage of the dimming port?
MisterTang
rimai wrote:Do you have a meter to test the voltage of the dimming port?
Yep, reading 4.48 VDC off of both of them.
Did you buy this controller from the webstore or someone else?
MisterTang
rimai wrote:Did you buy this controller from the webstore or someone else?
I bought it from Bay City, but they indicated that since they didn't have my order in stock, they ordered it from you and shipped direct to me. The box that it came in has your address on it.
Is the screen showing 95%?
If you change the code to 50%, what voltage do you get in the dimming ports?
MisterTang
rimai wrote:Is the screen showing 95%?
Yes
rimai wrote:If you change the code to 50%, what voltage do you get in the dimming ports?
The same voltage, and I did verify the screen is showing 50%.
EDIT:
Since my dimming is PWM, shouldn't it be at a steady voltage?
MisterTang
Would it help at all if I took measurements of what the DC Pump dongle was outputting through the three-prong connector?
No it varies just like analog.
MisterTang
Okay, I've pulled all my custom stuff out, and am not using the dimming ports at all, and I'm still measuring the same voltage on them. This is my code as-is right now.
    ReefAngel.AddWaterLevelExpansion();  // Water Level Expansion Module
    ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port7Bit | Port8Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port7Bit | Port8Bit;
    ReefAngel.OverheatShutoffPorts = Port3Bit;
    ReefAngel.Relay.On( Port4 );
    ReefAngel.Relay.On( Port7 );
    ReefAngel.Relay.DelayedOn( Port2,3 );
    ReefAngel.StandardHeater( Port3,779,789 );
    ReefAngel.Portal( "MisterTang" );
That doesn't seem correct.
I think you better off send all of it to me and I'll be able to tell exactly what is wrong.
