I am trying to turn the ATO pump on at 48% and off above 50%.
ATO = Sensor 4
Relay = Box1_Port7
ReefAngel.FeedingModePortsE[0] = Port1Bit | Port7Bit;
ReefAngel.WaterChangePorts = Port5Bit;
ReefAngel.WaterChangePortsE[0] = Port1Bit | Port7Bit;
ReefAngel.Relay.On( Port2 );
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port4 );
ReefAngel.StandardHeater( Port7,750,755 );
ReefAngel.Relay.DelayedOn( Box1_Port1,10 );
ReefAngel.StandardLights( Box1_Port3,20,0,8,0 );
//ReefAngel.WaterLevelATO(4)(Box1_Port7,60,48,51 );
ReefAngel.RF.SetMode( Constant,30,10 );
ReefAngel.DCPump.SetMode( Constant,50,10 );
ReefAngel.DCPump.ExpansionChannel[0] = None;
if (ReefAngel.WaterLevel.GetLevel(4)<=48) ReefAngel.Relay.On(Box1_Port7);
if (ReefAngel.WaterLevel.GetLevel(4)>=50) ReefAngel.Relay.Off(Box1_Port7);
ReefAngel.Portal( "Paul_Velasco" );
Error:
sketch_mar16a.cpp: In function 'void loop()':
sketch_mar16a:103: error: 'class ReefAngelClass' has no member named 'WaterLevel'
sketch_mar16a:104: error: 'class ReefAngelClass' has no member named 'WaterLevel'
Oh yeah water levels to not show same on Portal and LCD Screen? I get 50 and 50 on LCD for Portal the numbers are way off???
