12 volt power expansion
- heatdissipation
Is there a diagram anywhere that maps out the ports on this module. I have looked for a diagram and searched the forums but haven't found an easy way to know which is which. I didn't want to ask such a simple question, I figured for sure someone had asked in the past. I know I could figure it out with a little trial and error, but thought I would ask first
- heatdissipation
Re: 12 volt power expansion
No need to be sorry I can figure it out. You do so much I feel guilty even asking such a simple question
If you are talking about the Power Control Expansion the ports go (if you have the front with the label facing you) from #1 on the Top Left to #8 on the top Right.
So the 2 on the Left side are #1 and 2, the 4 on the bottom are 3, 4, 5, & 6 and the 2 on the right side are 7 on the bottom and 8 on the top.
Roberto feel free to use this in the manual if you want. I just threw it together.
- heatdissipation
Awe. Thank you so much. You just saved me a lot of trial and error. I really appreciate it. That's a perfect example.
