Wifi will not connect after firmware update
lurch
Re: Wifi will not connect after firmware update
Post by lurch »
so is this the way it should look if my wifi name is centurylink and no password
sendln 'centurylink'
sendln ' '
lurch
Post by lurch »
Can someone confirm this is the right way to input program
lurch
Post by lurch »
Is there anyone that checks this forum?
lurch wrote:so is this the way it should look if my wifi name is centurylink and no password
sendln ' '
no, this is not correct. in the previous post, Roberto gave the commands to issue the wifi name and password.
sendln 'set wlan ssid centurylink'
sendln 'set wlan pass '
I'm not positive about the no password though. I would have to look at the manual again.
Sent from my Moto X
lurch
Post by lurch »
Thank you for your help. Do you have a link to the manual?
lurch wrote:Thank you for your help. Do you have a link to the manual?
no. it is on the roving network (www.rovingnetworks.com) website.
i just looked at the manual and it does not appear to allow for empty or no passphrase. you will need to change the encryption to be none or open and not use wpa2 if you do not want a passphrase. I have not played around with no passphrase to know the answer for you and that example is not in the manual.
clw143
Post by clw143 »
Is there something we can do prior to going to 1.1.1 so this issue wont occur?
fit
Post by fit »
I am trying to understand this so I am going to ask two questions that may seem extremely basic:
Why are all new WiFi adapters not sent with this already configured? Roberto just told me to do this procedure on a recently purchased, brand new WiFi adapter?
What is the purpose of changing the ttl file so that it has the correct SSID and password if I am going to run the WiFi Wizard after runing this Macro?
If you run the macro, you don't need to use the wifi utility anymore. It should be already configured.
fit
Post by fit »
Thanks. And why are the WiFi adapters shipped without this Macro run on them please?
They usually are.
I just want to make sure you don't have one that got missed.
rschneider77
Post by rschneider77 »
I have tried all of the above and still the wifi device will not connect. Any other suggestions?
Can you post the log of what you got on tera term screen?
rschneider77
There is nothing the screen is blank.
rschneider77
So, there is no fix for the wifi unit?
rschneider77
Just tried to use the script again, the following was shown on the screen.
à`Pqpàp >xðÀ 0 y`Ã}_~¹ý:þ÷þ EÜ(?ø>?Ѿû ýøÈþàwôô¾ÿÎ0¿?ðÿÿð
þð
You are probably not choosing the correct baud rate.
Please follow the instructions carefully.
Try using 57600 baud as mentioned in the instruction.
rschneider77
Changing the baud rate to 57600 did not change anything. Still will not work with the wifi utility.
Are you talking about wifi utility or Tera term. Two different ways of setting it up.
Can you post the log you get with 57600 baud?
rschneider77
Everything loads with terterm. When the script is complete, I then try the wifi utility and it gives me an error, no blinking lights. The wifi screen says, Please wait, attempting to communicate with the Reef Angel wifi attachment.
"Error" Please disconnect and then reconnect the Reef Angel wifi attachment from the USB ttl cable and try again.
If you use tera term and it is successful, the wifi attachment should already be configured and you don't need the wifi utility anymore.
If the wifi attachment has no blinking lights, it is probably not working and it shouldn't be able to accept the script from tera term.
Can you please post the log of tera term?
rschneider77
The characters listed below are the only things printed on the teraterm screen.
Ðþÿþ
That means the macro never ran correctly.
Is the green LED blinking? How about blue?
If you want to send it back to have it checked out, send me a PM.
rschneider77
I sent a PM. Did you receive it?
Yes
psirex
Post by psirex »
rimai wrote:sendln 'set wlan ssid testing'
sendln 'set wlan pass a01b02c03d'
is this all we need to change in the ttl file?
greatwyt
Post by greatwyt »
hi @rimai please can you assist i followed the steps after making error of update copied and pasted earlier post of steps...
1. I updated firmware and then was trying every method for connection with no results.
2. I tried then to revert firmware via Macro suggested by 'Rimai' but was automatically changing to baud rate of 57600 (I thought I was supposed to do that)
did exactly this then:
Tried with default Baud of 9600 but no luck. blue lights are still flashing
any further advice?
Can you post the log of tera term?
greatwyt
Post by greatwyt »
sorry double post
greatwyt
Post by greatwyt »
CMD
factory RESET
Set Factory Defaults
<4.41> reboot
*Reboot*CMD
set ftp address 198.175.253.161
AOK
<4.41> save
Storing in config
<4.41> set wlan ssid Pretty-Fly-forset wlan pass Khe
AOK
<4.41> set option deviceid ReefAngelWifi
AOK
<4.41> set w j 1
AOK
<4.41> set c c 0
AOK
<4.41> set c r 0
AOK
<4.41> set c o 0
AOK
<4.41> set i d 1
AOK
<4.41> set c i 3
AOK
<4.41> set dns name http://www(.)reefangel(.)com
AOK
<4.41> set i h 23.24.193.9
AOK
<4.41> set i r 80
AOK
<4.41> set i f 0x06
AOK
<4.41> set s t 0x10
AOK
<4.41> set u m 2
AOK
<4.41> set i p 2
AOK
<4.41> set u b 57600
AOK
<4.41> set s p 0
AOK
<4.41> set c s 1420
AOK
<4.41> save
Storing in config
<4.41> save user
Storing in user
<4.41> reboot
*Reboot*
edited passphrase
edited brackets into url
also full name of my ssid is Pretty-Fly-for-a-Wi-Fi and is entered as such into Tll file
