Wifi will not connect after firmware update
Re: Wifi will not connect after firmware update
And you tried this with both 9600 (default) and 57600 baud, correct?
Can you post what you get in Tera Term window for both speeds?
I hadn't until now and ISSUE IS SOLVED.rimai wrote:And you tried this with both 9600 (default) and 57600 baud, correct?
This was my mistake (for informational purposes):
1. I updated firmware and then was trying every method for connection with no results.
2. I tried then to revert firmware via Macro suggested by 'Rimai' but was automatically changing to baud rate of 57600 (I thought I was supposed to do that)
3. Tried with default Baud of 9600 and it worked! Blue flashing stopped.
4. Ran the wifi utility again and it's connected!
Thanks for your patience with me
I am having the same problem have down loaded everything wanting to make sure that I change the ssid to my one at home and the pass to my password at home for the wifi
Does this procedure downgrade fix the issue so the WiFI attachment works again with the Wifi Utility? or is it simply to updated you WiFI information?
I did this in my previous home and got it working. I just moved and was going to update the info but the WiFi utility still doe snot connect to the attachment.
This is unrelated to the wifi utility. It should connect regardless of upgrade or not.
My wifi utility gives me an error, It says unable to connect additional updates required please see below. There is nothing below.
That fixed my issue, thank you. Now I have to try to get the port forwarding setup in the crappy Router brighthouse gave me.rimai wrote:Try this
http://forum.reefangel.com/viewtopic.php?p=46978#p46978
Im trying this but I dont see were to change the SSID and passphrase in the programx=0
while x<>121
messagebox 'Start WiFly module configuration' 'Webscan Config Program'
;this macro all sent with 5 msec character delay
timeout=10
send '$$$'
wait 'CMD'
sendln 'factory RESET'
wait 'Set Factory Defaults'
sendln 'reboot'
wait '*READY*'
; Begin user settings
send '$$$'
wait 'CMD'
sendln 'set ftp address 198.175.253.161'
wait'AOK'
sendln 'save'
wait 'config'
sendln 'set wlan ssid testing'
wait 'AOK'
sendln 'set wlan pass a01b02c03d'
wait 'AOK'
sendln 'set option deviceid ReefAngelWifi'
wait 'AOK'
sendln 'set w j 1'
wait 'AOK'
sendln 'set c c 0'
wait 'AOK'
sendln 'set c r 0'
wait 'AOK'
sendln 'set c o 0'
wait 'AOK'
sendln 'set i d 1'
wait 'AOK'
sendln 'set c i 3'
wait 'AOK'
sendln 'set dns name www.reefangel.com'
wait 'AOK'
sendln 'set i h 198.171.134.6'
wait 'AOK'
sendln 'set i r 80'
wait 'AOK'
sendln 'set i f 0x06'
wait 'AOK'
sendln 'set s t 0x10'
wait 'AOK'
sendln 'set u m 2'
wait 'AOK'
sendln 'set i p 2'
wait 'AOK'
sendln 'set u b 57600'
wait 'AOK'
sendln 'set s p 0'
wait 'AOK'
sendln 'set c s 1420'
wait 'AOK'
sendln 'save'
wait 'config'
sendln 'save user'
wait 'user'
sendln'reboot'
;inputbox 'Configure another module (y/n)' 'WiFly Config Program'
; convert inputstr to ASCII int value
; str2code x inputstr
endwhile
while x<>121
timeout=10
send '$$$'
wait 'CMD'
sendln 'reboot'
wait '*READY*'
send '$$$'
wait 'CMD'
wait'AOK'
sendln 'save'
wait 'config'
wait 'AOK'
wait 'AOK'
wait 'AOK'
sendln 'set w j 1'
wait 'AOK'
sendln 'set c c 0'
wait 'AOK'
sendln 'set c r 0'
wait 'AOK'
sendln 'set c o 0'
wait 'AOK'
sendln 'set i d 1'
wait 'AOK'
sendln 'set c i 3'
wait 'AOK'
wait 'AOK'
wait 'AOK'
sendln 'set i r 80'
wait 'AOK'
wait 'AOK'
wait 'AOK'
sendln 'set u m 2'
wait 'AOK'
sendln 'set i p 2'
wait 'AOK'
wait 'AOK'
sendln 'set s p 0'
wait 'AOK'
wait 'AOK'
sendln 'save'
wait 'config'
sendln 'save user'
wait 'user'
sendln'reboot'
endwhile
so is this the way it should look if my wifi name is centurylink and no password
sendln 'centurylink'
sendln ' '
sendln ' '
Can someone confirm this is the right way to input program
Is there anyone that checks this forum?
no, this is not correct. in the previous post, Roberto gave the commands to issue the wifi name and password.lurch wrote:so is this the way it should look if my wifi name is centurylink and no password
sendln ' '
sendln 'set wlan ssid centurylink'
sendln 'set wlan pass '
I'm not positive about the no password though. I would have to look at the manual again.
Sent from my Moto X
Thank you for your help. Do you have a link to the manual?
no. it is on the roving network (www.rovingnetworks.com) website.lurch wrote:Thank you for your help. Do you have a link to the manual?
i just looked at the manual and it does not appear to allow for empty or no passphrase. you will need to change the encryption to be none or open and not use wpa2 if you do not want a passphrase. I have not played around with no passphrase to know the answer for you and that example is not in the manual.
Is there something we can do prior to going to 1.1.1 so this issue wont occur?
I am trying to understand this so I am going to ask two questions that may seem extremely basic:
Why are all new WiFi adapters not sent with this already configured? Roberto just told me to do this procedure on a recently purchased, brand new WiFi adapter?
What is the purpose of changing the ttl file so that it has the correct SSID and password if I am going to run the WiFi Wizard after runing this Macro?
If you run the macro, you don't need to use the wifi utility anymore. It should be already configured.
Thanks. And why are the WiFi adapters shipped without this Macro run on them please?
They usually are.
I just want to make sure you don't have one that got missed.
I have tried all of the above and still the wifi device will not connect. Any other suggestions?
Can you post the log of what you got on tera term screen?
There is nothing the screen is blank.
So, there is no fix for the wifi unit?
Just tried to use the script again, the following was shown on the screen.
à`Pqpàp >xðÀ 0 y`Ã}_~¹ý:þ÷þ EÜ(?ø>?Ѿû ýøÈþàwôô¾ÿÎ0¿?ðÿÿð
þð
þð
You are probably not choosing the correct baud rate.
Please follow the instructions carefully.
Try using 57600 baud as mentioned in the instruction.
Changing the baud rate to 57600 did not change anything. Still will not work with the wifi utility.
Are you talking about wifi utility or Tera term. Two different ways of setting it up.
Can you post the log you get with 57600 baud?
Everything loads with terterm. When the script is complete, I then try the wifi utility and it gives me an error, no blinking lights. The wifi screen says, Please wait, attempting to communicate with the Reef Angel wifi attachment.
"Error" Please disconnect and then reconnect the Reef Angel wifi attachment from the USB ttl cable and try again.
