Relay Expansion, Wavemaker programming,web banner
Re: Relay Expansion, Wavemaker programming,web banner
The add-on relay box works correctly, right? Just not showing on the portal?
cosmith71 forget the suggestions I made in the last post.
I forgot that he said it is working and showing up in the Andriod App, but not the Portal.
So the answer to your question
cosmith71 wrote:The add-on relay box works correctly, right? Just not showing on the portal?
would be yes it works, but doesn't show in the portal.
That was in the OP, but I forgot it and thought it wasn't working at all.
Gugs Jr
Post by Gugs Jr »
I have the Dip switches in side the Relay Expansion Module set to ID1 (all off), I tried setting it up to ID2 and it wouldn't communicate with the expansion relay.
Gugs Jr
Post by Gugs Jr »
Not sure what else to try or what else I can do. They show up when I scroll through the Reef Angel itself. Just every where but the portal
I think it is related to the space in your username or the portal key.
Try using this:
ReefAngel.Portal("Gugs%20Jr");
And make sure to disable the portal key.
If it works, then you can go ahead and change the code to use the key again.
GugsJr
Post by GugsJr »
rimai wrote:I think it is related to the space in your username or the portal key.
Try using this:
Still nothing I even tried making a new user name without the space
I don't see anything in the log for this username :(
The only thing I can think of is somehow the settings are messed up in the wifi attachment if you can communicate with it using the android app.
Try following this post to see if it helps:
http://forum.reefangel.com/viewtopic.php?f=3&t=4601
Gugs Jr
Post by Gugs Jr »
rimai wrote:I don't see anything in the log for this username :(
That worked! and it also allowed the web banner to function properly
Thank you for your help everyone
