Relay Expansion Code Issues
tanked_kiwi
Post by tanked_kiwi »
Hi,
I've just tried to use the relay box expansion code and keep having an error when I compile. This happens even when I use some code generated by the wizard.
Example:
    ReefAngel.FeedingModePorts = Port3Bit | Port5Bit | Port6Bit | Port8Bit;
    ReefAngel.WaterChangePorts = Port3Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
    ReefAngel.LightsOnPorts = Port2Bit | Port4Bit;
    ReefAngel.LightsOnPortsE[0] = Port1Bit;
    ReefAngel.ActinicLights( Port2 );
    ReefAngel.ActinicLights( Port4 );
    ReefAngel.SingleATOLow( Port5 );
    ReefAngel.PWM.Channel0PWMSlope();
    ReefAngel.PWM.Channel2PWMParabola();
    ReefAngel.PWM.Channel3PWMParabola();
    ReefAngel.Portal( "tanked_kiwi" );
This Is what the compiler shows:
Dimming Signal
Wifi Attachment
Dimming Expansion Module
2014 Main Screen
Simple Menu
sketch_jun22a.cpp: In function 'void setup()':
sketch_jun22a:46: error: 'class ReefAngelClass' has no member named 'FeedingModePortsE'
sketch_jun22a:49: error: 'class ReefAngelClass' has no member named 'WaterChangePortsE'
sketch_jun22a:52: error: 'class ReefAngelClass' has no member named 'LightsOnPortsE'
sketch_jun22a:55: error: 'class ReefAngelClass' has no member named 'OverheatShutoffPortsE'
Any Idea why this is happening?
Evan.
Re: Relay Expansion Code Issues
You need to set a function to at least one port in the expansion box.
tanked_kiwi
Gotcha, thanks
