Expansion Hub Dead
newtoke
Expansion Hub Dead
Post by newtoke »
I bought the expansion hub a few months back and it had been working just fine. This morning anything not connected to it did not work (Dimmer and Sal). I removed the Expansion hub and just plugged in the dimmer and the dimmer worked fine. Any advice on what I can do here?
Re: Expansion Hub Dead
Seems like the hub is bad.
Does the led on the side light up?
Check for water damage. When something works for a while and just quit, there is a good chance that water made its way into the case.
newtoke
Post by newtoke »
It flickering like a bad power connection... No way for water to get into the case as all of the expansion hubs and relay are actually above water and the tank velcroed to the top of a cabinet. I can send pictures if you like.
Does it do the same if you wiggle the usb cable that goes from the hub to the relay box?
Try another cable to see if it is the cable.
newtoke
Post by newtoke »
If I wiggle the cable. I get more flicker... I then reused the cable with my dimmer and it worked fine.
newtoke
Post by newtoke »
Any thoughts of what to try next Roberto?
I thought you said it worked fine... :? Did not?
newtoke
Post by newtoke »
No the cable worked fine... I tested the cable to make sure it was not the problem. The hub itself is still a problem. Sorry for the confusion
Ahhh.
Does it still look flickering with just the hub connected with nothing connected to it?
newtoke
Post by newtoke »
Yes just the hub with nothing else... Its a random flicker, like a short or loose connection.
Send it back for me to take a look at it.
PM for RMA #.
Barendvh
Post by Barendvh »
Hi guys
I have the same problem. I calibrated the ORP probe and the next minute everything connected the USB expansion module stopped working? Tried to re program replace cables but nothing works.
What can you suggest I do?
Barendvh
Post by Barendvh »
newtoke wrote:Yes just the hub with nothing else... Its a random flicker, like a short or loose connection.
Hi Newtoke did you get it sorted? If so what id you do.
