RANet Ready Relay Box
Hey Guys,
Here is a video of the RANet module controlling a RANet ready relay box.
[youtube]http://www.youtube.com/watch?v=JMBARknej_Y[/youtube]
This relay box will be the first of the wireless expansion modules that will be available shortly.
Re: RANet Ready Relay Box
That's awesome!
89delta
Post by 89delta »
Oh wow....am so loving the creativity from you guys.
Very Cool.
When you asked for suggestions in the other thread I was thinking of a wireless Relay or Power control module.
Smotz
Post by Smotz »
Very Nice. How far will the wireless reach? standard stuff? Kicking myself for wiring an extension plug to the pump in the basement.
That is awesome. How is the fallbacks set on the ports? Is it through software or jumpers?
howaboutme
Post by howaboutme »
Love it! Aesthetically it is very nice as well. Wireless reach info is important too and would love to know if putting a relay in my basement is okay.
Jack
One thing about zigbee is that devices are also repeaters if I'm not mistaken. Would we be able to talk to standard zigbee devices at all? And would other zigbee devices in the house help (if I'm correct on zigbee retransmission?) the RANet signals? If so then we'd definitely be able to extend to other areas as far as range. Hell, next device request - RANet repeater :)
lnevo wrote:That is awesome. How is the fallbacks set on the ports? Is it through software or jumpers?
As simple as this:
  ReefAngel.Relay.RANetFallBackE[0]=Port7Bit;
This line will turn port 7 on and all other ports off.
Smotz wrote:Very Nice. How far will the wireless reach? standard stuff? Kicking myself for wiring an extension plug to the pump in the basement.
The manufacturer advertises 300ft, but that is usually open field range.
davaraj
Post by davaraj »
As simple as this:
I have the return pump on port 5 and skimmer on port 1 on the wireless relay box. Recently the relay box has been losing connectivity from the RA controller on and off and this effectively stops the return pump and skimmer. Is there a way to have the 2 ports to be on even when the relay box loses connectivity from the RA controller?
Dr Davaraj
  ReefAngel.Relay.RANetFallBackE[0]=Port1Bit | Port5Bit;
davaraj
Post by davaraj »
Thanks Lee. I'll add that into my code.
Smotz
Post by Smotz »
are these available?
I think I still have one left
Smotz
Post by Smotz »
rimai wrote:I think I still have one left
Oi..Gonna hold out until they're officially released.
bencollinz
Post by bencollinz »
how do I get this to work? It's just flashing a white light at me...
    #include <SoftwareSerial.h>
    #define Heater      1
    #define Return      2
    #define HeaterTk2   3
    #define Skimmer     4
    #define Vortech1    5
    #define Vortech2    6
    #define ATO         7
    #define Sump Light  8
byte vtechmode, vtSpeed, vtDuration;
        ReefAngel.FeedingModePorts = Port2Bit;
        // ReefAngel.FeedingModePortsE[0] = 0;
        // ReefAngel.WaterChangePorts = Port7Bit | Port4Bit | Port5Bit | Port6Bit;
        // ReefAngel.WaterChangePortsE[0] = 0;
        // ReefAngel.LightsOnPorts = 0;
        // ReefAngel.LightsOnPortsE[0] = 0;
        // ReefAngel.OverheatShutoffPortsE[0] = 0;
        ReefAngel.Relay.On( Port2 );
        ReefAngel.Relay.On( Port3 );
        ReefAngel.Relay.On( Port4 );
        ReefAngel.Relay.On( Port5 );
        // Hardcode calibrations
        ReefAngel.PHMin=576; // PH7.0
        ReefAngel.PHMax=842; // PH10.0
        ReefAngel.SalMax=3300; // 35ppt
    vtechmode=InternalMemory.RFMode_read();
    vtSpeed=InternalMemory.RFSpeed_read();
    vtDuration=InternalMemory.RFDuration_read();
    static unsigned long feeding;
    ReefAngel.StandardHeater( Port1,778,782 );
        ReefAngel.WaterLevelATO( Port7,180,71,74 );
        ReefAngel.StandardLights( Port8,15,0,2,0 );
        ReefAngel.PWM.SetChannel( 0,PWMSlope(19,00,21,00,15,51,20,0) );  //MOON
        ReefAngel.PWM.SetChannel( 1,PWMSlope(12,30,20,00,15,50,30,0) );  //RB
        ReefAngel.PWM.SetChannel( 2,PWMSlope(12,20,20,00,15,95,30,0) ); //WHITE
        ReefAngel.PWM.SetChannel( 3,PWMSlope(12,15,20,00,15,70,30,0) );  //BLUE&CYAN
        ReefAngel.PWM.SetChannel( 4,PWMSlope(12,00,20,30,15,70,30,0) ); //UV
        if ( ReefAngel.HighATO.IsActive())
          ReefAngel.Relay.On(Port2);
          ReefAngel.Relay.Off(Port2);
if (hour() >=13 && hour() < 20)
        // if (ReefAngel.RF.Mode==Night) ReefAngel.RF.SetMode(Feeding_Stop,0,0);
        ReefAngel.RF.UseMemory=true;
        // ReefAngel.RF.SetMode(ReefCrest,60,20);
             feeding=now();
             if (now()-feeding<5400) {
            // if (now()-feeding > 1 && now()-feeding < 5400) { // 1 second after feeding mode until 60 minutes after feeding mode.
  ReefAngel.RF.UseMemory=false;
    ReefAngel.RF.SetMode(Smart_NTM,75,10);
        ReefAngel.RF.SetMode(Constant,10,0);
         if (vtechmode!=InternalMemory.RFMode_read())
          InternalMemory.RFMode_write(vtechmode);
         if (vtSpeed!=InternalMemory.RFSpeed_read())
          InternalMemory.RFSpeed_write(vtSpeed);
         if (vtDuration!=InternalMemory.RFDuration_read())
          InternalMemory.RFDuration_write(vtDuration);
        ReefAngel.Portal( "bencollinz" );
      char text[7];
        ReefAngel.LCD.DrawDate( 6, 2 );
    ReefAngel.LCD.DrawText(0,255,18,12,"EcoSmart Vortech");
  ReefAngel.LCD.Clear(255, 1, 19, 128, 29);
  if (vtechmode == 0) ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,255,35,21,"Constant");
  else if (vtechmode == 1) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,42,21,"Lagoon");
  else if (vtechmode == 2) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,25,21,"Reef Crest");
  else if (vtechmode == 3) ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE,255,22,21,"Short Pulse");
  else if (vtechmode == 4) ReefAngel.LCD.DrawLargeText(COLOR_PINK,255,25,21,"Long Pulse");
  else if (vtechmode == 5) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,8,21,"Nutrient Trnsp.");
  else if (vtechmode == 6) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,23,21,"Tidal Swell");
  else if (vtechmode == 9) ReefAngel.LCD.DrawLargeText(COLOR_WHITE,0,45,21,"Night");
  ReefAngel.LCD.DrawText(0,255,4,30,"RF Speed:");
  ReefAngel.LCD.Clear(255,59,29,128,39);
  ReefAngel.LCD.DrawText(COLOR_BLUE, DefaultBGColor,71,31,vtSpeed);
  ReefAngel.LCD.DrawText(COLOR_BLUE, DefaultBGColor,90,31,"/");
  ReefAngel.LCD.DrawText(COLOR_BLUE, DefaultBGColor,100,31,vtDuration);
  ReefAngel.LCD.DrawText(0,255,10,40,"Salt");
  ReefAngel.LCD.DrawLargeText(COLOR_INDIANRED, 255, 10, 50, text, Num8x8);
 /* ReefAngel.LCD.DrawText(0,255,50,40,"Fresh");
  ReefAngel.LCD.DrawLargeText(COLOR_INDIANRED, 255, 50, 50, text, Num8x8);
  ReefAngel.LCD.DrawText(0,255,100,40,"pH");
  ReefAngel.LCD.DrawLargeText(COLOR_PLUM, 255, 85, 50, text, Num8x8);
  ReefAngel.LCD.DrawText(0,255,13,58,"Salinity");
  ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN, 255, 13, 68, text, Num8x8);
  // water level
    ReefAngel.LCD.DrawText(0,255,68,58,"WL");
    ReefAngel.LCD.DrawText( COLOR_CORNFLOWERBLUE,255, 68, 68, ReefAngel.WaterLevel.GetLevel() );
        ReefAngel.LCD.DrawOutletBox( 12, 108, TempRelay );
         // Relay Expansion
       ReefAngel.LCD.DrawOutletBox( 12, 120, TempRelay );
    /* void Heater2(byte HeaterRelay, int LowTemp, int HighTemp)
    if (ReefAngel.Params.Temp[T2_PROBE] == 0) return; // Don't turn the heater on if the temp is reading 0
    if (ReefAngel.Params.Temp[T2_PROBE] <= LowTemp && ReefAngel.Params.Temp[T2_PROBE] > 0) ReefAngel.Relay.On(HeaterRelay); // If sensor 2 temperature <= LowTemp - turn on heater
    if (ReefAngel.Params.Temp[T2_PROBE] >= HighTemp) ReefAngel.Relay.Off(HeaterRelay); // If sensor 2 temperature >= HighTemp - turn off heater
    void Heater1(byte HeaterRelay, int LowTemp, int HighTemp)
    if (ReefAngel.Params.Temp[T1_PROBE] == 0) return; // Don't turn the heater on if the temp is reading 0
    if (ReefAngel.Params.Temp[T1_PROBE] <= LowTemp && ReefAngel.Params.Temp[T1_PROBE] > 0) ReefAngel.Relay.On(HeaterRelay); // If sensor 2 temperature <= LowTemp - turn on heater
    if (ReefAngel.Params.Temp[T1_PROBE] >= HighTemp) ReefAngel.Relay.Off(HeaterRelay); // If sensor 2 temperature >= HighTemp - turn off heater
billw
Post by billw »
rimai wrote:Hey Guys,
Roberto, what is the availability of the wireless relay box?
I have a couple.
PM for details.
