RANet Ready Dimmable LED Driver
- GiraffeCat
Re: RANet Ready Dimmable LED Driver
How many channels is each driver going to have? Is this going to be a RANet Dimming Expansion?
What is the range of voltages it can handle? Fixed voltage input, or selectable/tolerant of 12 to 48 volt range?
LMK.
Thank You,
GC
LMK.
Thank You,
GC
.....Your forefathers wisely set aside their compassion - Steeled themselves for what needed to be done.......
Each module has 3 channels capable of delivering anywhere from 350mA to 1000mA each channel.
You can use a power supply from 12V all the way up to 48V, depending on the number of LEDs you want to have in each string.
- GiraffeCat
Does it need a separate power source to run the electronics, or does it sample from the led source?
Many uses this RANet has. (In Yoda speak)
Late,
GC
Late,
GC
Yes, you will need a power supply to feed power to as many LEDs you wish to light up.
For example, 3 LEDs, you only need 12V, but for 12-13LEDs, you need 48V.
It's the same as the LDD drivers.
Each channel is configured individually so you can set them to run at different amperages if you wish. Anywhere from 250mA to 1000mA each channel.
- GiraffeCat
Forgive me. Let me ask a different way.
Does the RANet LED Driver need a power source of its own - to run the wireless communication portion of the driver. ( Not the LED power source - A separate source independent of the led power source .)
LMK,
GC
LMK,
GC
No....
It has a built-in DC-DC converter to reduce the 12V-48V down to 5V to run the internal circuit.
- GiraffeCat
Update? I'm sure more than one person is wondering how it's going.
LUK,
GC
LUK,
GC
Someone is already running it on his system
Maybe he will post some pics
rimai wrote:Someone is already running it on his system
Pics will be here shortly dimmer is running great however my cheap ebay power supply burned out. Waiting on a new one to get here to take pics.
- Rodasphoto
- Contact:
How much do these cost and how can I order a couple of them?
Im getting an overheat problem with the LED driver, channel 0 was shutting off for a few seconds about every 10 seconds. I unplugged the driver and checked the temp inside the case and found it at 150 degrees. I took the cover off and let it cool. Plugged it back in and it appears to be ok for now except the green power led is no longer working.
I have the driver in my cabinet that is running about 72 degrees right now.
Channel 0 is being run at 950 ma
Channel 1 and 2 are run at 600 ma
This is going to end up being a problem in the summer when my thermostat will not be set at 66 degrees.
Ok well the dimmer does not dim anymore everything is just at 100 percent or off nothing in between for all 3 channels
