Jebeo Battery Backup - only functions on battery mode
hedrickms
Re: Jebeo Battery Backup - only functions on battery mode
Post by hedrickms »
Correct. Even with everything connected I get nothing on one of connectors. I do hear a click wth both power supplies when I unplug and replug them.
That doesn't make sense then... :?
Do both pumps run at slower speed when in battery mode?
hedrickms
Post by hedrickms »
Yes... They did but will double check when I get back home. I was thinking a bad connection somewhere in the box but maybe not.
hedrickms
Post by hedrickms »
Maybe my code too? I will double check the last code I used as well and post a copy to see if I made any errors.
Just to simplify and make sure that it is not code related, use this code:
ReefAngel.PWM.SetDaylight(100);
hedrickms
Post by hedrickms »
I cant remember right now but if there are any references to memory= true or false and sync/anti-sync should I remove them?
Yes, remove them.
hedrickms
Post by hedrickms »
Ok I think I figured out the problem. Its not code but a cable/PWM wire (if you can believe it). One of the PWM wires doesnt connect very well (at the pin). I was able to bend the wire a little to make it work but not sure how long it will last. I will start again with some code to see if it is in fact working/syncing with two pumps and that the battery works.
Thanks again for all the awesome support
hedrickms
Post by hedrickms »
after fixing the cable everything is good. I updated my code and all is functioning. Thanks for the help
Awesome!!
hedrickms
Re: Jebeo Battery Backup - still having issues after testing
Post by hedrickms »
Ok sorry to be a pest. I am still having issues with the backup unit. I got it operational and all pumps are running however now for whatever reason the backup is not working. I checked the battery for voltage (11.5v) and even plugged it into a trickle charger to just be sure and still nothing when power off. The unit does click when power goes on and there is voltage coming from the sunpower. Its like nothing is being fed back to he Jebaos.
Any ideas?
hedrickms
Post by hedrickms »
I also noticed that the unit wasn't charging (battery was dropping voltage overnight) yesterday. When I checked the battery before charging it was only 5v and I let it sit with light on it for a day and still 5v so I charged it so now its at 11.5v (well see what it is tomorrow). Either way nothing functioning when power off.
Are the relays still clicking when you apply power to the port 1 and 2?
hedrickms
Post by hedrickms »
If I pullout each plug and plug back in both click. When I turn off the power I hear a click (cant tell if its both) and turn it back on I hear both click
If it is clicking, it should work.
I wonder if the low battery voltage was the issue. Did it not spin with the battery charged either?
hedrickms
Post by hedrickms »
no it wont spin even after charging. I also tried just one Jebao still nothing. Could there be a short somewhere I can check? Im not sure its charging either (not sure why the battery had low voltage).
hedrickms
Post by hedrickms »
I can confirm that the battery is not charging. After charging the battery to 11.7v and hooking up to the backup it is down to 7v and the Jebaos where running on power (not battery).
Is the issue the box or the battery?
Did you use a different battery charger to charge it?
Is the solar panel blinking blue when it gets light?
If you connect the solar panel directly to the battery, does it charge the battery?
hedrickms
Post by hedrickms »
I did charge the battery with a different charger only after I discovered it wasnt charging with the backup unit. It was a 12v trickle charger I use for my bike. It did charge the battery to 11.7v. I immediately plugged it into the unit to see if it would run the Jebaos and nothing. After letting it sit plugged in and running on full power I checked the battery again and it was down to 7v. I didnt try charging directly with the SunForce but I know it is putting out voltage (checked) and because the kids hid the extra cords somewhere LOL.
Does the SunForce panels blink blue? or is there a light somewhere?
I will go and check and let you know.
Ok I checked and didnt see any blue blinking (although I am not sure what is supposed to blink).
hedrickms
Post by hedrickms »
Ok I figured it out again... although Im not sure why it was working (ever) last week. I took the unit apart and noticed that you have the circuit board labeled and the battery and solar ports are backward from what the manual said so I switched them and all is working now. I think you need to double check the manual and swap the picture/instructions for the battery and solar hookups.
We will see tomorrow if the battery still holds a charge/keeps charging.
Thanks again and sorry I am such a noob :)
It actually it doesn't matter which side you plug the battery or charger. There is a bridge connecting one side to the other. So it will work whichever way you plug them in.
hedrickms
Post by hedrickms »
Well that is strange because mine is only working one way. Hmmm now I want to figure out what is wrong
