Wifi Module Solid Red and Yellow
paperdesk
Post by paperdesk »
I just got my RA and wifi attachment, but am having trouble getting the wifi attachment to work. I got to a point where the wifi attachment had a slow blinking green light, and an IP address of 0.0.0.0.2000. I tried running through the programming again toget a proper IP address but to no avail. Now, however, the red and yellow lights have gone on and stay on solid.
What to do now?
paperdesk
Re: Wifi Module Solid Red and Yellow
Post by paperdesk »
And it gives me an error code:
ERROR - Please disconnect and then reconnect the Reef Angel Wifi Attachment from the USB-TTL cable and try again.
Red and yellow solid is not normal. Please PM for RMA.
paperdesk
Post by paperdesk »
I have another FTDI device I used that I thought might be causing problems, but it's on another COM port, so I think that is ruled out.
I'll PM you about the RMA.
By the way, for the record, I connected via Teraterm, and got the following Gibberish:
3e ó¤l
8ÿ{4$Ðý3e¤;e ó¤dÿs?¼Æ×þó¤l
ó¤|?¼ÆÕþ;¢s¦d¬ó¤|ÿy4,Æ ýó¤d¬
s¦d¬3eÿs?<?ó¤l ýó¦d¬
3§d¬ó¤\ÿ³ü´%ÆÑýó¤l
9ÿ³4$ÆÉýó¤|
3¢3§dÿ³4$ÆÉý;£s¦d¬ó¤\ÿ3?¼ÇÑÿó¤l
8
9ÿ{?¼ÆÖý3e ó
9ÿ{<Æ ý#
8
ó¤|ÿx4$Ðý9
ó¤|
;ÿx4$ÆÉý3e s¦d¤9ÿs?¼Æ3e
paperdesk
Post by paperdesk »
I tried to replace the firmware via Teraterm as outlined here http://forum.reefangel.com/viewtopic.php?f=3&t=4601
and got more gibberish. After setting the baud rate to 57600 I got the following:
*FAIL*, handshake
EAP TRY #3
*FAIL*, handshake
EAP-TLS Client APP version 1.00 10/11/12
*FAIL*, handshake
EAP TRY #2
*FAIL*, handshake
EAP TRY #3
*FAIL*, handshake
paperdesk
Post by paperdesk »
Ok, I got the replacement attachment and it works! However, I'm a little confused about the wifi test code. When I upload the wifi test code it shuts down everything in my tank. Does this mean that it is replacing my current sketch? I re-uploaded my previous sketch and was up and running again. I am able to view my tank info in the demo server occasionally and often get an "unable to connect to the server" message. Then, mysteriously, it will sometimes work.
I can currently view my info in the portal and the demo server, though under "connection" in the portal it says "unreachable address".
The test code is just a test, you have to put your ino back when done testing. Unreachable means your port forwarding needs to be setup.
paperdesk
Post by paperdesk »
OK got it. Thought port forwarding was good but will double check settings.
paperdesk
Post by paperdesk »
Got it all ironed out, somehow one of the settings didn't "take" the first time, but it's working now!
